[Swift-devel] Question regarding ip.address
Ben Clifford benc at hawaga.org.uk
Tue Jul 22 11:41:20 CDT 2008
On Tue, 22 Jul 2008, Zhao Zhang wrote:
> I have a question about the following parameter of swift.
> 1. Is this feature enabled in current release of swift?
> 2. If I specify it as "swift -ip.address 172.17.3.16 first.swift", is that
> correct?
I usually set GLOBUS_HOSTNAME in the environment rather than specifying a
commandline parameter; that works for me regularly.
eg:
  $ export GLOBUS_HOSTNAME=182.17.3.16
If you're adding in non-Swift stuff like provider-deef, I haven't tested
how that responds to the above configuration.
