[Swift-devel] Question regarding ip.address
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Jul 22 12:24:59 CDT 2008
On Tue, 2008-07-22 at 12:17 -0500, Ioan Raicu wrote:
> Zhao,
> You just need a way to pass an IP address to the deef provider... so
> might as well do:
> export GLOBUS_HOSTNAME=182.17.3.16
> and then read the environment variable "GLOBUS_HOSTNAME" in the deef
> provider and get the IP address that way.  This is assuming that the
> -ip.address option in Swift doesn't work as you expected.
If you're not using the jglobus libraries to start the notification
service, nor are you explicitly querying CoGProperties, then chances are
that Swift option won't work for you.
