[Swift-devel] Re: Question and update on swift script
James Simone simone at fnal.gov
Wed Jan 30 11:30:14 CST 2008
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Dear swift developers,
Do you have a system diagram for swift?
I'd like to show one as part of my talk on Friday.
		--jim
James Simone wrote:
| Thanks Mihael!
| Mihael Hategan wrote:
| | Mike is probably on or around a plane.
| | Here's my feeble attempt at it.
| | Mihael
| | On Fri, 2008-01-25 at 10:20 -0600, James Simone wrote:
| |> Hi Mike,
| |> Could you please send us your target version of the 2-pt QCD workflow?
| |> The target swiftscipt would not necessarily be able to run with current
| |> swift, but it would include syntax changes that are/will be under
| development.
| |>     Thanks,
| |>     --jim
| |> Michael Wilde wrote:
| |>> Hi all,
| |>> I made some good progress yesterday in understanding the swift
code for
| |>> the 2ptHL workflow, and started revising it.
| |>> Im doing the following:
| |>> - giving all files a mnemonic type name
| |>> - creating compound types that encapsulate each data/info file pair
| |>> - putting each set of nested foreach loops into a procedure (for
better
| |>> abstraction)
| |>> - changing the mapper to tie it to each data type
| |>> For now, Im also pulling the two cache-loading functions out of the
| |>> workflow, as it seems like these should be part of the runtime
| |>> environment, rather than in the workflow script. Do you feel the same?
| |>> I *thought* that you had a set of wrappers that were python stubs for
| |>> simulated execution, but the wrappers Don sent me looked like wrappers
| |>> that call the *real* code. So for now I'll create my own simple
| stubs to
| |>> test the data flow with.
| |>> Ive got many more questions that Im collecting, but for now I only
need
| |>> the answer to this one:
| |>> In the nested loops that call the function Onia() (lines 136-148
in the
| |>> attached numbered listing), is the actual call at line 145 correct?
| |>> This call is passing the same "HeavyQuarkConverted" as both the
| |>> anti-quark and quark1. Im assuming that is the correct intent.
| |>> Also, its passing only the wave[1] wave file (1S) each time (second of
| |>> the three wave files d, 1S, 2S). (Same is true for BStaggered).
| |>> Lastly, Onia seems to be getting called with successive pairs of
| |>> converted heavy quark files, but it seems like the final call is going
| |>> to get a null file for the second file, as the value of "bindex"
| will be
| |>> one past the last converted heavy quark file computed.
| |>> Im looking for ways to avoid the way the current script needs to
| compute
| |>> the various array indices, but Im not likely to find something that
| |>> doesnt require a language change. Was this approach of computing the
| |>> indices something that your team liked, or did not like, about this
| |>> swift script?
| |>> I'll try to send more details and questions as I proceed.
| |>> A few of these are below. If you have a moment to consider these, that
| |>> will help me get a better understanding of the environment.
| |>> Thanks,
| |>> - Mike
| |>> qcopy: I need to learn more about how you manage data and use dcache,
| |>> but for now, I get the essence if this. Can you point me to a
qcopy doc
| |>> page though? I couldnt find one.
| |>> tag_array_mapper: I can guess how this works, but can you send me the
| |>> code for it? It seems like the order in which it fills the array must
| |>> match the index computations in your swift script. Looks to me
like the
| |>> leftmost tag in the format script is varied fastest (ie, is the "least
| |>> significant index"). Is this correct?
| |>> kappa value passing bug: you allude to this in a comment.  Was this a
| |>> swift problem or a problem in the py wrapper?  Resolved or still open?
| |>> If Swift, I can test to see if I can reproduce it. But I suspect you
| |>> were testing against a pretty old version of swift?
| |>> Is the notion of an "info" file paired with most data files a standard
| |>> metadata convention for LQCD? (Ie, Im assuming that this is done
| |>> throughout your apps, not just in this swift example, right?  If
so, it
| |>> seems to justify a mapping convention so that you can simply pass a
| |>> "Quark" object, and have the data and info files passed automatically,
| |>> together. You can then dereference the object top extract each field
| |>> (file).
| |>> Are the file naming conventions set by the tag mapper the ones already
| |>> in use by the current workflow system? I.e., the order of the foreach
| |>> loops and hence of the mappings was chosen carefully to match the
| |>> existing file-naming conventions?
| |>> How is the name of the ensemble chosen? Does it have a relation to the
| |>> phyarams? Is it a database key? (It seems opaque to the current swift
| |>> example. Is that by preference or was there a desire to expose its
| |>> structure? Its its contents related to the phyparams?  Or when
| looked up
| |>> in a DB, does it yield the phyparams?
| |> _______________________________________________
| |> Swift-devel mailing list
| |> Swift-devel at ci.uchicago.edu
| |> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.8 (MingW32)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAkegtCYACgkQCdIhGvtLXB0YXACfWs5Va2U23eTxzCiSnjPVcRqe
Jp0AnjeQ9ONnE0H9FHp97RIcOm80bENd
=CIo3
-----END PGP SIGNATURE-----
