[Swift-devel] Re: Question and update on swift script
    James Simone
    simone at fnal.gov
    Tue Jan 29 18:22:16 CST 2008
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Thanks Mihael!
Mihael Hategan wrote:
| Mike is probably on or around a plane.
| Here's my feeble attempt at it.
| Mihael
| On Fri, 2008-01-25 at 10:20 -0600, James Simone wrote:
|> Hi Mike,
|> Could you please send us your target version of the 2-pt QCD workflow?
|> The target swiftscipt would not necessarily be able to run with current
|> swift, but it would include syntax changes that are/will be under
development.
|> 	Thanks,
|> 	--jim
|> Michael Wilde wrote:
|>> Hi all,
|>> I made some good progress yesterday in understanding the swift code for
|>> the 2ptHL workflow, and started revising it.
|>> Im doing the following:
|>> - giving all files a mnemonic type name
|>> - creating compound types that encapsulate each data/info file pair
|>> - putting each set of nested foreach loops into a procedure (for better
|>> abstraction)
|>> - changing the mapper to tie it to each data type
|>> For now, Im also pulling the two cache-loading functions out of the
|>> workflow, as it seems like these should be part of the runtime
|>> environment, rather than in the workflow script. Do you feel the same?
|>> I *thought* that you had a set of wrappers that were python stubs for
|>> simulated execution, but the wrappers Don sent me looked like wrappers
|>> that call the *real* code. So for now I'll create my own simple
stubs to
|>> test the data flow with.
|>> Ive got many more questions that Im collecting, but for now I only need
|>> the answer to this one:
|>> In the nested loops that call the function Onia() (lines 136-148 in the
|>> attached numbered listing), is the actual call at line 145 correct?
|>> This call is passing the same "HeavyQuarkConverted" as both the
|>> anti-quark and quark1. Im assuming that is the correct intent.
|>> Also, its passing only the wave[1] wave file (1S) each time (second of
|>> the three wave files d, 1S, 2S). (Same is true for BStaggered).
|>> Lastly, Onia seems to be getting called with successive pairs of
|>> converted heavy quark files, but it seems like the final call is going
|>> to get a null file for the second file, as the value of "bindex"
will be
|>> one past the last converted heavy quark file computed.
|>> Im looking for ways to avoid the way the current script needs to
compute
|>> the various array indices, but Im not likely to find something that
|>> doesnt require a language change. Was this approach of computing the
|>> indices something that your team liked, or did not like, about this
|>> swift script?
|>> I'll try to send more details and questions as I proceed.
|>> A few of these are below. If you have a moment to consider these, that
|>> will help me get a better understanding of the environment.
|>> Thanks,
|>> - Mike
|>> qcopy: I need to learn more about how you manage data and use dcache,
|>> but for now, I get the essence if this. Can you point me to a qcopy doc
|>> page though? I couldnt find one.
|>> tag_array_mapper: I can guess how this works, but can you send me the
|>> code for it? It seems like the order in which it fills the array must
|>> match the index computations in your swift script. Looks to me like the
|>> leftmost tag in the format script is varied fastest (ie, is the "least
|>> significant index"). Is this correct?
|>> kappa value passing bug: you allude to this in a comment.  Was this a
|>> swift problem or a problem in the py wrapper?  Resolved or still open?
|>> If Swift, I can test to see if I can reproduce it. But I suspect you
|>> were testing against a pretty old version of swift?
|>> Is the notion of an "info" file paired with most data files a standard
|>> metadata convention for LQCD? (Ie, Im assuming that this is done
|>> throughout your apps, not just in this swift example, right?  If so, it
|>> seems to justify a mapping convention so that you can simply pass a
|>> "Quark" object, and have the data and info files passed automatically,
|>> together. You can then dereference the object top extract each field
|>> (file).
|>> Are the file naming conventions set by the tag mapper the ones already
|>> in use by the current workflow system? I.e., the order of the foreach
|>> loops and hence of the mappings was chosen carefully to match the
|>> existing file-naming conventions?
|>> How is the name of the ensemble chosen? Does it have a relation to the
|>> phyarams? Is it a database key? (It seems opaque to the current swift
|>> example. Is that by preference or was there a desire to expose its
|>> structure? Its its contents related to the phyparams?  Or when
looked up
|>> in a DB, does it yield the phyparams?
|> _______________________________________________
|> Swift-devel mailing list
|> Swift-devel at ci.uchicago.edu
|> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.8 (MingW32)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAkefwzgACgkQCdIhGvtLXB3jxwCgvTGUPVmVC1Jrvs4NDSfUOs8E
BGkAoOofKeUArKdq0J9CpqLpoSKqIPYC
=d1mF
-----END PGP SIGNATURE-----
