[Swift-devel] Re: gridmap file for tg-uc
    Mike Kubal
    mikekubal at yahoo.com
    Wed Jan 23 16:07:39 CST 2008
Here's a tar file of the script and the logs.
I get the same error when running against teraport.
Mike
--- Ben Clifford <benc at hawaga.org.uk> wrote:
> yes, looks like an OSG rather than teragrid error.
> mike kubal, send the sites.xml file that you are
> using.
> On Wed, 23 Jan 2008, Michael Wilde wrote:
> > info from Joe, below.
> > MikeK: where are you expecting files to move from
> and to in this script?
> > - MikeW
> > On 1/23/08 3:33 PM, joseph insley wrote:
> > > Mike,
> > > You are indeed n the grid-mapfile on the UC/ANL
> TeraGrid resource:
> > > insley at tg-viz-login1:~> grep Kubal
> /etc/grid-security/grid-mapfile
> > > "/DC=org/DC=doegrids/OU=People/CN=Michael Kubal
> 486347" kubal
> > > However, looks like the error is coming from the
> Teraport resource, not
> > > TeraGrid.   I am not as knowledgeable about that
> system, but I would assume
> > > that the same gx-request command should work
> there as well.
> > > joe.
> > > On Jan 23, 2008, at 3:15 PM, Mike Kubal wrote:
> > > > Hi Joe and Mike,
> > > > I used the gx-request again to add myself to
> the
> > > > gridmap on UC's teragrid again. It seemed to
> go
> > > > smoothly, just like the time before.
> > > > Though I still get the following error message
> when
> > > > running my Swift script:
> > > > Execution failed:
> > > >         Could not initialize shared directory
> on
> > > > teraport
> > > > Caused by:
org.globus.cog.abstraction.impl.file.FileResourceException:
> > > > Error communicating with the GridFTP server
> > > > Caused by:
> > > >         Server refused performing the request.
> Custom
> > > > message: Bad password. (error code 1) [Nested
> > > > exception message:  Custom message: Unexpected
> reply:
> > > > 530-Login incorrect. :
> gridmap.c:globus_gss_assist_map_and_authorize:1910:
> > > > 530-Error invoking callout
530-globus_callout.c:globus_callout_handle_call_type:727:
> > > > 530-The callout returned an error
> > > > 530-prima_module.c:Globus Gridmap Callout:430:
> > > > 530-Gridmap lookup failure: Could not retrieve
> mapping
> > > > for  /DC=org/DC=doegrids/OU=People/CN=Michael
> Kubal
> > > > 486347 from identity mapping server
> > > > 530-
> > > > 530 End.]
> > > > Before running I also removed the certificates
> dir in
> > > > ~mkubal/.globus.
> > > > Any suggestions?
> > > > Thanks,
> > > > Mike
> > > > --- joseph insley <insley at mcs.anl.gov
> <mailto:insley at mcs.anl.gov>> wrote:
> > > > > Mike,
> > > > > You should be able to do this yourself using
> the
> > > > > gx-request command.
> > > > > See more info at:
http://www.teragrid.org/userinfo/access/auth_gxmap.php
> > > > > joe.
> > > > > On Oct 29, 2007, at 2:07 PM, Mike Kubal
> wrote:
> > > > > > Hi Joe,
> > > > > > Please add me to gridmap file for tg-uc.
> My
> > > > > subject is
> Kubal
> > > > > 486347
> > > > > > My user name is kubal.
> > > > > > Thanks,
> > > > > > Mike
> __________________________________________________
> > > > > > Do You Yahoo!?
> > > > > > Tired of spam?  Yahoo! Mail has the best
> spam
> > > > > protection around
> > > > > > http://mail.yahoo.com
____________________________________________________________________________________
> > > > Be a better friend, newshound, and know-it-all
> with Yahoo! Mobile.  Try it
> > > > now.
http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
> > > joseph a. insley
> > > insley at mcs.anl.gov <mailto:insley at mcs.anl.gov>
> > > mathematics & computer science division
> (630) 252-5649
> > > argonne national laboratory
>          (630) 252-5986
> > > (fax)
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Never miss a thing.  Make Yahoo your home page.
http://www.yahoo.com/r/hs
Type: application/x-tar
Desc: 2238658463-swift_job.tar
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20080123/c01e7ba0/attachment.tar>
