[Swift-devel] Re: gridmap file for tg-uc
    Ben Clifford
    benc at hawaga.org.uk
    Wed Jan 23 15:46:24 CST 2008
yes, looks like an OSG rather than teragrid error.
mike kubal, send the sites.xml file that you are using.
On Wed, 23 Jan 2008, Michael Wilde wrote:
> info from Joe, below.
> MikeK: where are you expecting files to move from and to in this script?
> - MikeW
> On 1/23/08 3:33 PM, joseph insley wrote:
> > Mike,
> > You are indeed n the grid-mapfile on the UC/ANL TeraGrid resource:
> > insley at tg-viz-login1:~> grep Kubal /etc/grid-security/grid-mapfile
> > "/DC=org/DC=doegrids/OU=People/CN=Michael Kubal 486347" kubal
> > However, looks like the error is coming from the Teraport resource, not
> > TeraGrid.   I am not as knowledgeable about that system, but I would assume
> > that the same gx-request command should work there as well.
> > joe.
> > On Jan 23, 2008, at 3:15 PM, Mike Kubal wrote:
> > > Hi Joe and Mike,
> > > I used the gx-request again to add myself to the
> > > gridmap on UC's teragrid again. It seemed to go
> > > smoothly, just like the time before.
> > > Though I still get the following error message when
> > > running my Swift script:
> > > Execution failed:
> > >         Could not initialize shared directory on
> > > teraport
> > > Caused by:
> > > org.globus.cog.abstraction.impl.file.FileResourceException:
> > > Error communicating with the GridFTP server
> > > Caused by:
> > >         Server refused performing the request. Custom
> > > message: Bad password. (error code 1) [Nested
> > > exception message:  Custom message: Unexpected reply:
> > > 530-Login incorrect. :
> > > gridmap.c:globus_gss_assist_map_and_authorize:1910:
> > > 530-Error invoking callout
> > > 530-globus_callout.c:globus_callout_handle_call_type:727:
> > > 530-The callout returned an error
> > > 530-prima_module.c:Globus Gridmap Callout:430:
> > > 530-Gridmap lookup failure: Could not retrieve mapping
> > > for  /DC=org/DC=doegrids/OU=People/CN=Michael Kubal
> > > 486347 from identity mapping server
> > > 530-
> > > 530 End.]
> > > Before running I also removed the certificates dir in
> > > ~mkubal/.globus.
> > > Any suggestions?
> > > Thanks,
> > > Mike
> > > --- joseph insley <insley at mcs.anl.gov <mailto:insley at mcs.anl.gov>> wrote:
> > > > Mike,
> > > > You should be able to do this yourself using the
> > > > gx-request command.
> > > > See more info at:
> > > http://www.teragrid.org/userinfo/access/auth_gxmap.php
> > > > joe.
> > > > On Oct 29, 2007, at 2:07 PM, Mike Kubal wrote:
> > > > > Hi Joe,
> > > > > Please add me to gridmap file for tg-uc. My
> > > > subject is
> > > > 486347
> > > > > My user name is kubal.
> > > > > Thanks,
> > > > > Mike
> > > > > __________________________________________________
> > > > > Do You Yahoo!?
> > > > > Tired of spam?  Yahoo! Mail has the best spam
> > > > protection around
> > > > > http://mail.yahoo.com
> > >       ____________________________________________________________________________________
> > > Be a better friend, newshound, and know-it-all with Yahoo! Mobile.  Try it
> > > now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
> > joseph a. insley
> > mathematics & computer science division       (630) 252-5649
> > argonne national laboratory                               (630) 252-5986
> > (fax)
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
