[Swift-devel] Re: gridmap file for tg-uc
    Mike Kubal
    mikekubal at yahoo.com
    Fri Jan 25 13:26:29 CST 2008
Perhaps this will provide some insight into the
problem.
I was able to get the Swift script to run successfully
and execute on the UC teragrid if I used
myproxy-logon, instead of grid-proxy-init to establish
my credentials. I did get the following warning:
2008-01-25 13:05:42,266-0600 WARN
JobSubmissionTaskHandler Failed to clean up job
java.lang.IllegalStateException: No registered
callback handler for
org.globus.gsi.gssapi.GlobusGSSCredentialImpl at ee5a0
6
        at
org.globus.cog.abstraction.impl.execution.gt2.CallbackHandlerManager.decreaseUsageCount(CallbackHandlerManag
er.java:33)
        at
org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.cleanup(JobSubmissionTaskHandler.java
:482)
        at
org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.statusChanged(JobSubmissionTaskHandle
r.java:475)
        at
org.globus.gram.GramJob.setStatus(GramJob.java:184)
        at
org.globus.gram.GramCallbackHandler.run(CallbackHandler.java:176)
        at java.lang.Thread.run(Thread.java:595)
--- Mike Kubal <mikekubal at yahoo.com> wrote:
> Here's a tar file of the script and the logs.
> I get the same error when running against teraport.
> Thanks,
> Mike
> --- Ben Clifford <benc at hawaga.org.uk> wrote:
> > yes, looks like an OSG rather than teragrid error.
> > mike kubal, send the sites.xml file that you are
> > using.
> > On Wed, 23 Jan 2008, Michael Wilde wrote:
> > > info from Joe, below.
> > > MikeK: where are you expecting files to move
> from
> > and to in this script?
> > > - MikeW
> > > On 1/23/08 3:33 PM, joseph insley wrote:
> > > > Mike,
> > > > You are indeed n the grid-mapfile on the
> UC/ANL
> > TeraGrid resource:
> > > > insley at tg-viz-login1:~> grep Kubal
> > /etc/grid-security/grid-mapfile
> > > > "/DC=org/DC=doegrids/OU=People/CN=Michael
> Kubal
> > 486347" kubal
> > > > However, looks like the error is coming from
> the
> > Teraport resource, not
> > > > TeraGrid.   I am not as knowledgeable about
> that
> > system, but I would assume
> > > > that the same gx-request command should work
> > there as well.
> > > > joe.
> > > > On Jan 23, 2008, at 3:15 PM, Mike Kubal wrote:
> > > > > Hi Joe and Mike,
> > > > > I used the gx-request again to add myself to
> > the
> > > > > gridmap on UC's teragrid again. It seemed to
> > go
> > > > > smoothly, just like the time before.
> > > > > Though I still get the following error
> message
> > when
> > > > > running my Swift script:
> > > > > Execution failed:
> > > > >         Could not initialize shared
> directory
> > on
> > > > > teraport
> > > > > Caused by:
org.globus.cog.abstraction.impl.file.FileResourceException:
> > > > > Error communicating with the GridFTP server
> > > > > Caused by:
> > > > >         Server refused performing the
> request.
> > Custom
> > > > > message: Bad password. (error code 1)
> [Nested
> > > > > exception message:  Custom message:
> Unexpected
> > reply:
> > > > > 530-Login incorrect. :
> gridmap.c:globus_gss_assist_map_and_authorize:1910:
> > > > > 530-Error invoking callout
530-globus_callout.c:globus_callout_handle_call_type:727:
> > > > > 530-The callout returned an error
> > > > > 530-prima_module.c:Globus Gridmap
> Callout:430:
> > > > > 530-Gridmap lookup failure: Could not
> retrieve
> > mapping
> > > > > for
> > Kubal
> > > > > 486347 from identity mapping server
> > > > > 530-
> > > > > 530 End.]
> > > > > Before running I also removed the
> certificates
> > dir in
> > > > > ~mkubal/.globus.
> > > > > Any suggestions?
> > > > > Thanks,
> > > > > Mike
> > > > > --- joseph insley <insley at mcs.anl.gov
> > <mailto:insley at mcs.anl.gov>> wrote:
> > > > > > Mike,
> > > > > > You should be able to do this yourself
> using
> > the
> > > > > > gx-request command.
> > > > > > See more info at:
http://www.teragrid.org/userinfo/access/auth_gxmap.php
> > > > > > joe.
> > > > > > On Oct 29, 2007, at 2:07 PM, Mike Kubal
> > wrote:
> > > > > > > Hi Joe,
> > > > > > > Please add me to gridmap file for tg-uc.
> > My
> > > > > > subject is
> > Kubal
> > > > > > 486347
> > > > > > > My user name is kubal.
> > > > > > > Thanks,
> > > > > > > Mike
> > __________________________________________________
> > > > > > > Do You Yahoo!?
> > > > > > > Tired of spam?  Yahoo! Mail has the best
> > spam
> > > > > > protection around
> > > > > > > http://mail.yahoo.com
____________________________________________________________________________________
> > > > > Be a better friend, newshound, and
> know-it-all
> > with Yahoo! Mobile.  Try it
> > > > > now.
http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
> > > > joseph a. insley
> > > > insley at mcs.anl.gov <mailto:insley at mcs.anl.gov>
> > > > mathematics & computer science division
> > (630) 252-5649
> > > > argonne national laboratory
> >          (630) 252-5986
> > > > (fax)
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
=== message truncated ===
Never miss a thing.  Make Yahoo your home page.
http://www.yahoo.com/r/hs
