[Swift-devel] Re: gridmap file for tg-uc
    Michael Wilde
    wilde at mcs.anl.gov
    Wed Jan 23 15:38:54 CST 2008
info from Joe, below.
MikeK: where are you expecting files to move from and to in this script?
- MikeW
On 1/23/08 3:33 PM, joseph insley wrote:
> Mike,
> You are indeed n the grid-mapfile on the UC/ANL TeraGrid resource:
> insley at tg-viz-login1:~> grep Kubal /etc/grid-security/grid-mapfile
> "/DC=org/DC=doegrids/OU=People/CN=Michael Kubal 486347" kubal
> However, looks like the error is coming from the Teraport resource, not
> TeraGrid.   I am not as knowledgeable about that system, but I would
> assume that the same gx-request command should work there as well.
> joe.
> On Jan 23, 2008, at 3:15 PM, Mike Kubal wrote:
>> Hi Joe and Mike,
>> I used the gx-request again to add myself to the
>> gridmap on UC's teragrid again. It seemed to go
>> smoothly, just like the time before.
>> Though I still get the following error message when
>> running my Swift script:
>> Execution failed:
>>         Could not initialize shared directory on
>> teraport
>> Caused by:
>> org.globus.cog.abstraction.impl.file.FileResourceException:
>> Error communicating with the GridFTP server
>> Caused by:
>>         Server refused performing the request. Custom
>> message: Bad password. (error code 1) [Nested
>> exception message:  Custom message: Unexpected reply:
>> 530-Login incorrect. :
>> gridmap.c:globus_gss_assist_map_and_authorize:1910:
>> 530-Error invoking callout
>> 530-globus_callout.c:globus_callout_handle_call_type:727:
>> 530-The callout returned an error
>> 530-prima_module.c:Globus Gridmap Callout:430:
>> 530-Gridmap lookup failure: Could not retrieve mapping
>> for  /DC=org/DC=doegrids/OU=People/CN=Michael Kubal
>> 486347 from identity mapping server
>> 530-
>> 530 End.]
>> Before running I also removed the certificates dir in
>> ~mkubal/.globus.
>> Any suggestions?
>> Thanks,
>> Mike
>> --- joseph insley <insley at mcs.anl.gov <mailto:insley at mcs.anl.gov>> wrote:
>>> Mike,
>>> You should be able to do this yourself using the
>>> gx-request command.
>>> See more info at:
>> http://www.teragrid.org/userinfo/access/auth_gxmap.php
>>> joe.
>>> On Oct 29, 2007, at 2:07 PM, Mike Kubal wrote:
>>>> Hi Joe,
>>>> Please add me to gridmap file for tg-uc. My
>>> subject is
>>> 486347
>>>> My user name is kubal.
>>>> Thanks,
>>>> Mike
>>>> __________________________________________________
>>>> Do You Yahoo!?
>>>> Tired of spam?  Yahoo! Mail has the best spam
>>> protection around
>>>> http://mail.yahoo.com
>> ____________________________________________________________________________________
>> Be a better friend, newshound, and
>> know-it-all with Yahoo! Mobile.  Try it now.
>> http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
> joseph a. insley
> mathematics & computer science division       (630) 252-5649
> argonne national laboratory                               (630) 252-5986
> (fax)
