[Swift-devel] tz
    Ben Clifford
    benc at hawaga.org.uk
    Mon Jan 14 16:17:04 CST 2008
This just appeared in CHANGES.txt:
> *** Hmm. Maybe we should use UTC for the timestamps.
It probably shouldn't be there.
You can use UTC for timestamps if you want by setting the unix timezone to
that (either system-wide or in TZ to override per shell); similarly any of
the other 500 or so timezones can be used in the same way. That's the same
way it works for pretty much all other unix programs.
