[Swift-devel] tz
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon Jan 14 16:27:59 CST 2008
I was referring to the changelog timestamps.
I wrote it because the previous changelog entry was... in the future. At
least from my perspective. It seemed odd. And funny.
On Mon, 2008-01-14 at 22:17 +0000, Ben Clifford wrote:
> This just appeared in CHANGES.txt:
> > *** Hmm. Maybe we should use UTC for the timestamps.
> It probably shouldn't be there.
> You can use UTC for timestamps if you want by setting the unix timezone to
> that (either system-wide or in TZ to override per shell); similarly any of
> the other 500 or so timezones can be used in the same way. That's the same
> way it works for pretty much all other unix programs.
