[Swift-devel] Re: latest attempt with GRAM4
Ben Clifford benc at hawaga.org.uk
Tue Feb 12 17:51:05 CST 2008
On Tue, 12 Feb 2008, Mike Kubal wrote:
> Yes, I believe you are right. The kickstart message
> may be only a warning. After digging a little deeper
> it appears the job is failing due to a project/account
> id problem. I get the following error:
> Caused by:
>         The executable could not be started., qsub:
> Invalid Account MSG=invalid account
> I am specifying the same TG-account in my site-file
> for the gram4 run that fails, as in the site-file for
> the pre-ws job that suceeds. This is the same project,
> TG-MCA01S018, that is set in my .tg_default_project
> file in ~kubal/ on the UC teragrid.
ok. there's something wrong there.
run the command: tgprojects
and paste its output.
also paste your sites file again.
