[Swift-devel] placement of large amounts of client side kickstart	records
    Ben Clifford
    benc at hawaga.org.uk
    Fri Feb 15 16:41:53 CST 2008
At present, kickstart records go to $PWD.
That's lame - 10000 jobs give 10000 files that are i) in $PWD and ii) all
in the same directory.
I'd like to do something about that.
i) is most important - perhaps put them first in a subdirectory named by
workflow run ID, eg fmri-20080215-1828-2d433ro1.d/
ii) matters a bit less; however, kickstart records could be staged back
into a hierarchy split up by job ID, in the same way that they are split
up on the execute side.
