[Swift-devel] Re: latest attempt with GRAM4
    Mike Kubal
    mikekubal at yahoo.com
    Tue Feb 12 17:14:21 CST 2008
With pre-WS-GRAM, it doesn't seem to matter which
account/project id I use where. I can have the
TG-MCB010025N specified in the sites-files and
TG-MCA01S018 specified in ~kubal/.tg-default_project
on the uc teragrid, or vice versa and it still works,
or having them match in both places.
With WS-GRAM, I have to use TG-MCB010025N, the local
uc-teragrid project id, in both places. Using
TG-MCA01S018, the teragrid wide charge number/account
number, causes the qsub failure error.
--- Michael Wilde <wilde at mcs.anl.gov> wrote:
> Mike, did you do a recent test with pre-WS-GRAM with
> the
> .tg_default_project file set *incorrectly*?
> I think the puzzle was why this would cause WS-GRAM
> to fail but not
> pre-WS-GRAM, as it would seem they would both get
> the TG account to use
> in the same manner.
> - mikew
> On 2/12/08 4:43 PM, Mike Kubal wrote:
> > Just to be sure I tested with pre-WS and it worked
> > also.
> > --- Mihael Hategan <hategan at mcs.anl.gov> wrote:
> >> Would it be worth trying to find out why it
> worked
> >> with pre-WS GRAM?
> >> Mihael
> >> On Tue, 2008-02-12 at 14:20 -0800, Mike Kubal
> wrote:
> >>> Thanks Joe. This solved the account id problem.
> >>> --- joseph insley <insley at mcs.anl.gov> wrote:
> >>>> Mike K,
> >>>> looks like you have the wrong value in your
> >>>> .tg_default_project file:
> >>>> insley at tg-viz-login1:~> more
> >>>> ~kubal/.tg_default_project
> >>>> TG-MCA01S018
> >>>> you should be using: TG-MCB010025N
> >>>> insley at tg-viz-login1:~> tgusage -i -u kubal
> >>>> [snip]
> >>>> Account: TG-MCA01S018
> >>>> Title: Computational Studies of Complex
> >> Processes in
> >>>> Biological
> >>>> Macromolecular Systems
> >>>> Resource: teragrid
> >>>> Local project name on dtf.anl.teragrid is
> >>>> TG-MCB010025N
> >>>> Allocation Period: 2007-08-03 to 2008-03-31
> >>>> Name (Last First) or Account       Total
> >>>> Remaining        Usage
> >>>>     Kubal  Michael                101880 SU
> >>>> 99358 SU       296 SU
> >>>>     TG-MCA01S018                  101880 SU
> >>>> 99358 SU      2522 SU
> >>>> On Feb 12, 2008, at 2:37 PM, Mihael Hategan
> >> wrote:
> >>>>> You should probably remove the line
> >> completely.
> >>>>> Did you chose a default project on the login
> >> node
> >>>> with tgprojects?
> >>>>> On Tue, 2008-02-12 at 12:34 -0800, Mike Kubal
> >>>> wrote:
> >>>>>> I tried running with the account id removed
> >> from
> >>>> the
> >>>>>> sites.file as in the following line:
> >>>>>> <profile namespace="globus" key=""></profile>
> >>>>>> but received the same error.
> >> wrote:
> >>>>>>> Is this the same for pre-WS GRAM?
> >>>>>>> On Tue, 2008-02-12 at 14:20 -0600, Stuart
> >> Martin
> >>>>>>> wrote:
> >>>>>>>> that's right, qsub is used for PBS (and
> >> some
> >>>>>>> others too)
> >>>>>>>> bsub is LSF
> >>>>>>>> condor_q for condor
> >>>>>>>> -Stu
> >>>>>>>> On Feb 12, 2008, at Feb 12, 2:15 PM, Mihael
> >>>>>>> Hategan wrote:
> >>>>>>>>> On Tue, 2008-02-12 at 12:09 -0800, Mike
> >> Kubal
> >>>>>>> wrote:
> >>>>>>>>>> I'll give it a try.
> >>>>>>>>>> When using GRAM4, is qsub the method used
> >> to
> >>>>>>>>>> ultimately put the job in the queue?
> >>>>>>>>> Looks like it. I also believe it's the
> >> case
> >>>> with
> >>>>>>> pre-ws gram. Stu
> >>>>>>>>> may be
> >>>>>>>>> able to clarify.
> >>>>>>>>>> MikeK
> >>>> wrote:
> >>>>>>>>>>> While this doesn't solve the underlying
> >>>>>>> problem, it
> >>>>>>>>>>> may help you get
> >>>>>>>>>>> this to work: log into tg-login1.uc...,
> >> set
> >>>>>>> this
> >>>>>>>>>>> project as default,
> >>>>>>>>>>> then remove the project spec from the
> >> sites
> >>>>>>> file and
> >>>>>>>>>>> try again.
> >>>>>>>>>>> Mihael
> >>>>>>>>>>> On Tue, 2008-02-12 at 11:36 -0800, Mike
> >>>> Kubal
> >>>>>>> wrote:
> >>>>>>>>>>>> Yes, I believe you are right. The
> >> kickstart
> >>>>>>>>>>> message
> >>>>>>>>>>>> may be only a warning. After digging a
> >>>> little
> >>>>>>>>>>> deeper
> >>>>>>>>>>>> it appears the job is failing due to a
> >>>>>>>>>>> project/account
> >>>>>>>>>>>> id problem. I get the following error:
> >>>>>>>>>>>> Caused by:
> >>>>>>>>>>>>        The executable could not be
> >>>> started.,
> >>>>>>>>>>> qsub:
> >>>>>>>>>>>> Invalid Account MSG=invalid account
> >>>>>>>>>>>> I am specifying the same TG-account in
> >> my
> >>>>>>>>>>> site-file
> >>>>>>>>>>>> for the gram4 run that fails, as in the
> >>>>>>> site-file
> >>>>>>>>>>> for
> >>>>>>>>>>>> the pre-ws job that suceeds. This is
> >> the
> >>>> same
> >>>>>>>>>>> project,
> >>>>>>>>>>>> TG-MCA01S018, that is set in my
> >>>>>>>>>>> .tg_default_project
> >>>>>>>>>>>> file in ~kubal/ on the UC teragrid.
> >>>>>>>>>>>> --- Ben Clifford <benc at hawaga.org.uk>
> >>>> wrote:
> >>>>>>>>>>>>> yeah, run that same without kickstart.
> >> the
> >>>>>>> error
> >>>>>>>>>>>>> reported is that
> >>>>>>>>>>>>> kickstart didn't work right - but
> >> there's
> >>>>>>>>>>> perhaps
> >>>>>>>>>>>>> some underlying error.
=== message truncated ===
      ____________________________________________________________________________________
Looking for last minute shopping deals?
Find them fast with Yahoo! Search.  http://tools.search.yahoo.com/newsearch/category.php?category=shopping
