[Swift-devel] Re: latest attempt with GRAM4
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Feb 12 17:17:12 CST 2008
Are you sure you were using PBS with pre-ws GRAM and not fork?
On Tue, 2008-02-12 at 15:14 -0800, Mike Kubal wrote:
> With pre-WS-GRAM, it doesn't seem to matter which
> account/project id I use where. I can have the
> TG-MCB010025N specified in the sites-files and
> TG-MCA01S018 specified in ~kubal/.tg-default_project
> on the uc teragrid, or vice versa and it still works,
> or having them match in both places.
> With WS-GRAM, I have to use TG-MCB010025N, the local
> uc-teragrid project id, in both places. Using
> TG-MCA01S018, the teragrid wide charge number/account
> number, causes the qsub failure error.
> --- Michael Wilde <wilde at mcs.anl.gov> wrote:
> > Mike, did you do a recent test with pre-WS-GRAM with
> > the
> > .tg_default_project file set *incorrectly*?
> > I think the puzzle was why this would cause WS-GRAM
> > to fail but not
> > pre-WS-GRAM, as it would seem they would both get
> > the TG account to use
> > in the same manner.
> > - mikew
> > On 2/12/08 4:43 PM, Mike Kubal wrote:
> > > Just to be sure I tested with pre-WS and it worked
> > > also.
> > > --- Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > >> Would it be worth trying to find out why it
> > worked
> > >> with pre-WS GRAM?
> > >> Mihael
> > >> On Tue, 2008-02-12 at 14:20 -0800, Mike Kubal
> > wrote:
> > >>> Thanks Joe. This solved the account id problem.
> > >>> --- joseph insley <insley at mcs.anl.gov> wrote:
> > >>>> Mike K,
> > >>>> looks like you have the wrong value in your
> > >>>> .tg_default_project file:
> > >>>> insley at tg-viz-login1:~> more
> > >>>> ~kubal/.tg_default_project
> > >>>> TG-MCA01S018
> > >>>> you should be using: TG-MCB010025N
> > >>>> insley at tg-viz-login1:~> tgusage -i -u kubal
> > >>>> [snip]
> > >>>> Account: TG-MCA01S018
> > >>>> Title: Computational Studies of Complex
> > >> Processes in
> > >>>> Biological
> > >>>> Macromolecular Systems
> > >>>> Resource: teragrid
> > >>>> Local project name on dtf.anl.teragrid is
> > >>>> TG-MCB010025N
> > >>>> Allocation Period: 2007-08-03 to 2008-03-31
> > >>>> Name (Last First) or Account       Total
> > >>>> Remaining        Usage
> > >>>>     Kubal  Michael                101880 SU
> > >>>> 99358 SU       296 SU
> > >>>>     TG-MCA01S018                  101880 SU
> > >>>> 99358 SU      2522 SU
> > >>>> On Feb 12, 2008, at 2:37 PM, Mihael Hategan
> > >> wrote:
> > >>>>> You should probably remove the line
> > >> completely.
> > >>>>> Did you chose a default project on the login
> > >> node
> > >>>> with tgprojects?
> > >>>>> On Tue, 2008-02-12 at 12:34 -0800, Mike Kubal
> > >>>> wrote:
> > >>>>>> I tried running with the account id removed
> > >> from
> > >>>> the
> > >>>>>> sites.file as in the following line:
> > >>>>>> <profile namespace="globus" key=""></profile>
> > >>>>>> but received the same error.
> > >> wrote:
> > >>>>>>> Is this the same for pre-WS GRAM?
> > >>>>>>> On Tue, 2008-02-12 at 14:20 -0600, Stuart
> > >> Martin
> > >>>>>>> wrote:
> > >>>>>>>> that's right, qsub is used for PBS (and
> > >> some
> > >>>>>>> others too)
> > >>>>>>>> bsub is LSF
> > >>>>>>>> condor_q for condor
> > >>>>>>>> -Stu
> > >>>>>>>> On Feb 12, 2008, at Feb 12, 2:15 PM, Mihael
> > >>>>>>> Hategan wrote:
> > >>>>>>>>> On Tue, 2008-02-12 at 12:09 -0800, Mike
> > >> Kubal
> > >>>>>>> wrote:
> > >>>>>>>>>> I'll give it a try.
> > >>>>>>>>>> When using GRAM4, is qsub the method used
> > >> to
> > >>>>>>>>>> ultimately put the job in the queue?
> > >>>>>>>>> Looks like it. I also believe it's the
> > >> case
> > >>>> with
> > >>>>>>> pre-ws gram. Stu
> > >>>>>>>>> may be
> > >>>>>>>>> able to clarify.
> > >>>>>>>>>> MikeK
> > >>>> wrote:
> > >>>>>>>>>>> While this doesn't solve the underlying
> > >>>>>>> problem, it
> > >>>>>>>>>>> may help you get
> > >>>>>>>>>>> this to work: log into tg-login1.uc...,
> > >> set
> > >>>>>>> this
> > >>>>>>>>>>> project as default,
> > >>>>>>>>>>> then remove the project spec from the
> > >> sites
> > >>>>>>> file and
> > >>>>>>>>>>> try again.
> > >>>>>>>>>>> Mihael
> > >>>>>>>>>>> On Tue, 2008-02-12 at 11:36 -0800, Mike
> > >>>> Kubal
> > >>>>>>> wrote:
> > >>>>>>>>>>>> Yes, I believe you are right. The
> > >> kickstart
> > >>>>>>>>>>> message
> > >>>>>>>>>>>> may be only a warning. After digging a
> > >>>> little
> > >>>>>>>>>>> deeper
> > >>>>>>>>>>>> it appears the job is failing due to a
> > >>>>>>>>>>> project/account
> > >>>>>>>>>>>> id problem. I get the following error:
> > >>>>>>>>>>>> Caused by:
> > >>>>>>>>>>>>        The executable could not be
> > >>>> started.,
> > >>>>>>>>>>> qsub:
> > >>>>>>>>>>>> Invalid Account MSG=invalid account
> > >>>>>>>>>>>> I am specifying the same TG-account in
> > >> my
> > >>>>>>>>>>> site-file
> > >>>>>>>>>>>> for the gram4 run that fails, as in the
> > >>>>>>> site-file
> > >>>>>>>>>>> for
> > >>>>>>>>>>>> the pre-ws job that suceeds. This is
> > >> the
> > >>>> same
> > >>>>>>>>>>> project,
> > >>>>>>>>>>>> TG-MCA01S018, that is set in my
> > >>>>>>>>>>> .tg_default_project
> > >>>>>>>>>>>> file in ~kubal/ on the UC teragrid.
> > >>>>>>>>>>>> --- Ben Clifford <benc at hawaga.org.uk>
> > >>>> wrote:
> > >>>>>>>>>>>>> yeah, run that same without kickstart.
> > >> the
> > >>>>>>> error
> > >>>>>>>>>>>>> reported is that
> > >>>>>>>>>>>>> kickstart didn't work right - but
> > >> there's
> > >>>>>>>>>>> perhaps
> > >>>>>>>>>>>>> some underlying error.
> === message truncated ===
>       ____________________________________________________________________________________
> Looking for last minute shopping deals?
> Find them fast with Yahoo! Search.  http://tools.search.yahoo.com/newsearch/category.php?category=shopping
