[Swift-devel] Re: latest attempt with GRAM4
    Michael Wilde
    wilde at mcs.anl.gov
    Tue Feb 12 16:51:31 CST 2008
Mike, did you do a recent test with pre-WS-GRAM with the
.tg_default_project file set *incorrectly*?
I think the puzzle was why this would cause WS-GRAM to fail but not
pre-WS-GRAM, as it would seem they would both get the TG account to use
in the same manner.
- mikew
On 2/12/08 4:43 PM, Mike Kubal wrote:
> Just to be sure I tested with pre-WS and it worked
> also.
> --- Mihael Hategan <hategan at mcs.anl.gov> wrote:
>> Would it be worth trying to find out why it worked
>> with pre-WS GRAM?
>> Mihael
>> On Tue, 2008-02-12 at 14:20 -0800, Mike Kubal wrote:
>>> Thanks Joe. This solved the account id problem.
>>> --- joseph insley <insley at mcs.anl.gov> wrote:
>>>> Mike K,
>>>> looks like you have the wrong value in your
>>>> .tg_default_project file:
>>>> insley at tg-viz-login1:~> more
>>>> ~kubal/.tg_default_project
>>>> TG-MCA01S018
>>>> you should be using: TG-MCB010025N
>>>> insley at tg-viz-login1:~> tgusage -i -u kubal
>>>> [snip]
>>>> Account: TG-MCA01S018
>>>> Title: Computational Studies of Complex
>> Processes in
>>>> Biological
>>>> Macromolecular Systems
>>>> Resource: teragrid
>>>> Local project name on dtf.anl.teragrid is
>>>> TG-MCB010025N
>>>> Allocation Period: 2007-08-03 to 2008-03-31
>>>> Name (Last First) or Account       Total
>>>> Remaining        Usage
>>>>     Kubal  Michael                101880 SU
>>>> 99358 SU       296 SU
>>>>     TG-MCA01S018                  101880 SU
>>>> 99358 SU      2522 SU
>>>> On Feb 12, 2008, at 2:37 PM, Mihael Hategan
>> wrote:
>>>>> You should probably remove the line
>> completely.
>>>>> Did you chose a default project on the login
>> node
>>>> with tgprojects?
>>>>> On Tue, 2008-02-12 at 12:34 -0800, Mike Kubal
>>>> wrote:
>>>>>> I tried running with the account id removed
>> from
>>>> the
>>>>>> sites.file as in the following line:
>>>>>> <profile namespace="globus" key=""></profile>
>>>>>> but received the same error.
>> wrote:
>>>>>>> Is this the same for pre-WS GRAM?
>>>>>>> On Tue, 2008-02-12 at 14:20 -0600, Stuart
>> Martin
>>>>>>> wrote:
>>>>>>>> that's right, qsub is used for PBS (and
>> some
>>>>>>> others too)
>>>>>>>> bsub is LSF
>>>>>>>> condor_q for condor
>>>>>>>> -Stu
>>>>>>>> On Feb 12, 2008, at Feb 12, 2:15 PM, Mihael
>>>>>>> Hategan wrote:
>>>>>>>>> On Tue, 2008-02-12 at 12:09 -0800, Mike
>> Kubal
>>>>>>> wrote:
>>>>>>>>>> I'll give it a try.
>>>>>>>>>> When using GRAM4, is qsub the method used
>> to
>>>>>>>>>> ultimately put the job in the queue?
>>>>>>>>> Looks like it. I also believe it's the
>> case
>>>> with
>>>>>>> pre-ws gram. Stu
>>>>>>>>> may be
>>>>>>>>> able to clarify.
>>>>>>>>>> MikeK
>>>> wrote:
>>>>>>>>>>> While this doesn't solve the underlying
>>>>>>> problem, it
>>>>>>>>>>> may help you get
>>>>>>>>>>> this to work: log into tg-login1.uc...,
>> set
>>>>>>> this
>>>>>>>>>>> project as default,
>>>>>>>>>>> then remove the project spec from the
>> sites
>>>>>>> file and
>>>>>>>>>>> try again.
>>>>>>>>>>> Mihael
>>>>>>>>>>> On Tue, 2008-02-12 at 11:36 -0800, Mike
>>>> Kubal
>>>>>>> wrote:
>>>>>>>>>>>> Yes, I believe you are right. The
>> kickstart
>>>>>>>>>>> message
>>>>>>>>>>>> may be only a warning. After digging a
>>>> little
>>>>>>>>>>> deeper
>>>>>>>>>>>> it appears the job is failing due to a
>>>>>>>>>>> project/account
>>>>>>>>>>>> id problem. I get the following error:
>>>>>>>>>>>> Caused by:
>>>>>>>>>>>>        The executable could not be
>>>> started.,
>>>>>>>>>>> qsub:
>>>>>>>>>>>> Invalid Account MSG=invalid account
>>>>>>>>>>>> I am specifying the same TG-account in
>> my
>>>>>>>>>>> site-file
>>>>>>>>>>>> for the gram4 run that fails, as in the
>>>>>>> site-file
>>>>>>>>>>> for
>>>>>>>>>>>> the pre-ws job that suceeds. This is
>> the
>>>> same
>>>>>>>>>>> project,
>>>>>>>>>>>> TG-MCA01S018, that is set in my
>>>>>>>>>>> .tg_default_project
>>>>>>>>>>>> file in ~kubal/ on the UC teragrid.
>>>>>>>>>>>> --- Ben Clifford <benc at hawaga.org.uk>
>>>> wrote:
>>>>>>>>>>>>> yeah, run that same without kickstart.
>> the
>>>>>>> error
>>>>>>>>>>>>> reported is that
>>>>>>>>>>>>> kickstart didn't work right - but
>> there's
>>>>>>>>>>> perhaps
>>>>>>>>>>>>> some underlying error.
> _____________________________________________________________________
>>>>>> _______________
> === message truncated ===
>       ____________________________________________________________________________________
> Be a better friend, newshound, and
> know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
