[Swift-devel] Re: latest attempt with GRAM4
Mike Kubal
mikekubal at yahoo.com
Tue Feb 12 16:20:27 CST 2008
Thanks Joe. This solved the account id problem.
--- joseph insley <insley at mcs.anl.gov> wrote:
> Mike K,
> looks like you have the wrong value in your
> .tg_default_project file:
> insley at tg-viz-login1:~> more
> ~kubal/.tg_default_project
> TG-MCA01S018
> you should be using: TG-MCB010025N
> insley at tg-viz-login1:~> tgusage -i -u kubal
> [snip]
> Account: TG-MCA01S018
> Title: Computational Studies of Complex Processes in
> Biological
> Macromolecular Systems
> Resource: teragrid
> Local project name on dtf.anl.teragrid is
> TG-MCB010025N
> Allocation Period: 2007-08-03 to 2008-03-31
> Name (Last First) or Account Total
> Remaining Usage
> Kubal Michael 101880 SU
> 99358 SU 296 SU
> TG-MCA01S018 101880 SU
> 99358 SU 2522 SU
> On Feb 12, 2008, at 2:37 PM, Mihael Hategan wrote:
> > You should probably remove the line completely.
> > Did you chose a default project on the login node
> with tgprojects?
> > On Tue, 2008-02-12 at 12:34 -0800, Mike Kubal
> wrote:
> >> I tried running with the account id removed from
> the
> >> sites.file as in the following line:
> >> <profile namespace="globus" key=""></profile>
> >> but received the same error.
> >> --- Mihael Hategan <hategan at mcs.anl.gov> wrote:
> >>> Is this the same for pre-WS GRAM?
> >>> On Tue, 2008-02-12 at 14:20 -0600, Stuart Martin
> >>> wrote:
> >>>> that's right, qsub is used for PBS (and some
> >>> others too)
> >>>> bsub is LSF
> >>>> condor_q for condor
> >>>> -Stu
> >>>> On Feb 12, 2008, at Feb 12, 2:15 PM, Mihael
> >>> Hategan wrote:
> >>>>> On Tue, 2008-02-12 at 12:09 -0800, Mike Kubal
> >>> wrote:
> >>>>>> I'll give it a try.
> >>>>>> When using GRAM4, is qsub the method used to
> >>>>>> ultimately put the job in the queue?
> >>>>> Looks like it. I also believe it's the case
> with
> >>> pre-ws gram. Stu
> >>>>> may be
> >>>>> able to clarify.
> >>>>>> MikeK
> wrote:
> >>>>>>> While this doesn't solve the underlying
> >>> problem, it
> >>>>>>> may help you get
> >>>>>>> this to work: log into tg-login1.uc..., set
> >>> this
> >>>>>>> project as default,
> >>>>>>> then remove the project spec from the sites
> >>> file and
> >>>>>>> try again.
> >>>>>>> Mihael
> >>>>>>> On Tue, 2008-02-12 at 11:36 -0800, Mike
> Kubal
> >>> wrote:
> >>>>>>>> Yes, I believe you are right. The kickstart
> >>>>>>> message
> >>>>>>>> may be only a warning. After digging a
> little
> >>>>>>> deeper
> >>>>>>>> it appears the job is failing due to a
> >>>>>>> project/account
> >>>>>>>> id problem. I get the following error:
> >>>>>>>> Caused by:
> >>>>>>>> The executable could not be
> started.,
> >>>>>>> qsub:
> >>>>>>>> Invalid Account MSG=invalid account
> >>>>>>>> I am specifying the same TG-account in my
> >>>>>>> site-file
> >>>>>>>> for the gram4 run that fails, as in the
> >>> site-file
> >>>>>>> for
> >>>>>>>> the pre-ws job that suceeds. This is the
> same
> >>>>>>> project,
> >>>>>>>> TG-MCA01S018, that is set in my
> >>>>>>> .tg_default_project
> >>>>>>>> file in ~kubal/ on the UC teragrid.
> >>>>>>>> --- Ben Clifford <benc at hawaga.org.uk>
> wrote:
> >>>>>>>>> yeah, run that same without kickstart. the
> >>> error
> >>>>>>>>> reported is that
> >>>>>>>>> kickstart didn't work right - but there's
> >>>>>>> perhaps
> >>>>>>>>> some underlying error.
_____________________________________________________________________
> >> _______________
> >>>>>>>> Never miss a thing. Make Yahoo your home
> >>> page.
> >>>>>>>> http://www.yahoo.com/r/hs
> >> _______________
> >>>>>> Be a better friend, newshound, and
> >>>>>> know-it-all with Yahoo! Mobile. Try it now.
http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
> >>> Swift-devel mailing list
> >>> Swift-devel at ci.uchicago.edu
http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
=== message truncated ===
____________________________________________________________________________________
Looking for last minute shopping deals?
Find them fast with Yahoo! Search. http://tools.search.yahoo.com/newsearch/category.php?category=shopping
