[Swift-devel] Re: latest attempt with GRAM4
    joseph insley
    insley at mcs.anl.gov
    Tue Feb 12 14:45:29 CST 2008
Mike K,
looks like you have the wrong value in your .tg_default_project file:
insley at tg-viz-login1:~> more ~kubal/.tg_default_project
TG-MCA01S018
you should be using: TG-MCB010025N
insley at tg-viz-login1:~> tgusage -i -u kubal
[snip]
Account: TG-MCA01S018
Title: Computational Studies of Complex Processes in Biological
Macromolecular Systems
Resource: teragrid
Local project name on dtf.anl.teragrid is TG-MCB010025N
Allocation Period: 2007-08-03 to 2008-03-31
Name (Last First) or Account       Total      Remaining        Usage
    Kubal  Michael                101880 SU     99358 SU       296 SU
    TG-MCA01S018                  101880 SU     99358 SU      2522 SU
On Feb 12, 2008, at 2:37 PM, Mihael Hategan wrote:
> You should probably remove the line completely.
> Did you chose a default project on the login node with tgprojects?
> On Tue, 2008-02-12 at 12:34 -0800, Mike Kubal wrote:
>> I tried running with the account id removed from the
>> sites.file as in the following line:
>> <profile namespace="globus" key=""></profile>
>> but received the same error.
>> --- Mihael Hategan <hategan at mcs.anl.gov> wrote:
>>> Is this the same for pre-WS GRAM?
>>> On Tue, 2008-02-12 at 14:20 -0600, Stuart Martin
>>> wrote:
>>>> that's right, qsub is used for PBS (and some
>>> others too)
>>>> bsub is LSF
>>>> condor_q for condor
>>>> -Stu
>>>> On Feb 12, 2008, at Feb 12, 2:15 PM, Mihael
>>> Hategan wrote:
>>>>> On Tue, 2008-02-12 at 12:09 -0800, Mike Kubal
>>> wrote:
>>>>>> I'll give it a try.
>>>>>> When using GRAM4, is qsub the method used to
>>>>>> ultimately put the job in the queue?
>>>>> Looks like it. I also believe it's the case with
>>> pre-ws gram. Stu
>>>>> may be
>>>>> able to clarify.
>>>>>> MikeK
>>>>>>> While this doesn't solve the underlying
>>> problem, it
>>>>>>> may help you get
>>>>>>> this to work: log into tg-login1.uc..., set
>>> this
>>>>>>> project as default,
>>>>>>> then remove the project spec from the sites
>>> file and
>>>>>>> try again.
>>>>>>> Mihael
>>>>>>> On Tue, 2008-02-12 at 11:36 -0800, Mike Kubal
>>> wrote:
>>>>>>>> Yes, I believe you are right. The kickstart
>>>>>>> message
>>>>>>>> may be only a warning. After digging a little
>>>>>>> deeper
>>>>>>>> it appears the job is failing due to a
>>>>>>> project/account
>>>>>>>> id problem. I get the following error:
>>>>>>>> Caused by:
>>>>>>>>        The executable could not be started.,
>>>>>>> qsub:
>>>>>>>> Invalid Account MSG=invalid account
>>>>>>>> I am specifying the same TG-account in my
>>>>>>> site-file
>>>>>>>> for the gram4 run that fails, as in the
>>> site-file
>>>>>>> for
>>>>>>>> the pre-ws job that suceeds. This is the same
>>>>>>> project,
>>>>>>>> TG-MCA01S018, that is set in my
>>>>>>> .tg_default_project
>>>>>>>> file in ~kubal/ on the UC teragrid.
>>>>>>>> --- Ben Clifford <benc at hawaga.org.uk> wrote:
>>>>>>>>> yeah, run that same without kickstart. the
>>> error
>>>>>>>>> reported is that
>>>>>>>>> kickstart didn't work right - but there's
>>>>>>> perhaps
>>>>>>>>> some underlying error.
>> _____________________________________________________________________
>> _______________
>>>>>>>> Never miss a thing.  Make Yahoo your home
>>> page.
>>>>>>>> http://www.yahoo.com/r/hs
>> _______________
>>>>>> Be a better friend, newshound, and
>>>>>> know-it-all with Yahoo! Mobile.  Try it now.
>> http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
>> _______________
>> Looking for last minute shopping deals?
>> Find them fast with Yahoo! Search.  http://tools.search.yahoo.com/
>> newsearch/category.php?category=shopping
joseph a. insley
mathematics & computer science division       (630) 252-5649
argonne national laboratory                               (630)
252-5986 (fax)
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20080212/ed1f58c9/attachment.html>
