[Swift-devel] Re: latest attempt with GRAM4
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Feb 12 16:23:34 CST 2008
Would it be worth trying to find out why it worked with pre-WS GRAM?
Mihael
On Tue, 2008-02-12 at 14:20 -0800, Mike Kubal wrote:
> Thanks Joe. This solved the account id problem.
> --- joseph insley <insley at mcs.anl.gov> wrote:
> > Mike K,
> > looks like you have the wrong value in your
> > .tg_default_project file:
> > insley at tg-viz-login1:~> more
> > ~kubal/.tg_default_project
> > TG-MCA01S018
> > you should be using: TG-MCB010025N
> > insley at tg-viz-login1:~> tgusage -i -u kubal
> > [snip]
> > Account: TG-MCA01S018
> > Title: Computational Studies of Complex Processes in
> > Biological
> > Macromolecular Systems
> > Resource: teragrid
> > Local project name on dtf.anl.teragrid is
> > TG-MCB010025N
> > Allocation Period: 2007-08-03 to 2008-03-31
> > Name (Last First) or Account       Total
> > Remaining        Usage
> >     Kubal  Michael                101880 SU
> > 99358 SU       296 SU
> >     TG-MCA01S018                  101880 SU
> > 99358 SU      2522 SU
> > On Feb 12, 2008, at 2:37 PM, Mihael Hategan wrote:
> > > You should probably remove the line completely.
> > > Did you chose a default project on the login node
> > with tgprojects?
> > > On Tue, 2008-02-12 at 12:34 -0800, Mike Kubal
> > wrote:
> > >> I tried running with the account id removed from
> > the
> > >> sites.file as in the following line:
> > >> <profile namespace="globus" key=""></profile>
> > >> but received the same error.
> > >> --- Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > >>> Is this the same for pre-WS GRAM?
> > >>> On Tue, 2008-02-12 at 14:20 -0600, Stuart Martin
> > >>> wrote:
> > >>>> that's right, qsub is used for PBS (and some
> > >>> others too)
> > >>>> bsub is LSF
> > >>>> condor_q for condor
> > >>>> -Stu
> > >>>> On Feb 12, 2008, at Feb 12, 2:15 PM, Mihael
> > >>> Hategan wrote:
> > >>>>> On Tue, 2008-02-12 at 12:09 -0800, Mike Kubal
> > >>> wrote:
> > >>>>>> I'll give it a try.
> > >>>>>> When using GRAM4, is qsub the method used to
> > >>>>>> ultimately put the job in the queue?
> > >>>>> Looks like it. I also believe it's the case
> > with
> > >>> pre-ws gram. Stu
> > >>>>> may be
> > >>>>> able to clarify.
> > >>>>>> MikeK
> > wrote:
> > >>>>>>> While this doesn't solve the underlying
> > >>> problem, it
> > >>>>>>> may help you get
> > >>>>>>> this to work: log into tg-login1.uc..., set
> > >>> this
> > >>>>>>> project as default,
> > >>>>>>> then remove the project spec from the sites
> > >>> file and
> > >>>>>>> try again.
> > >>>>>>> Mihael
> > >>>>>>> On Tue, 2008-02-12 at 11:36 -0800, Mike
> > Kubal
> > >>> wrote:
> > >>>>>>>> Yes, I believe you are right. The kickstart
> > >>>>>>> message
> > >>>>>>>> may be only a warning. After digging a
> > little
> > >>>>>>> deeper
> > >>>>>>>> it appears the job is failing due to a
> > >>>>>>> project/account
> > >>>>>>>> id problem. I get the following error:
> > >>>>>>>> Caused by:
> > >>>>>>>>        The executable could not be
> > started.,
> > >>>>>>> qsub:
> > >>>>>>>> Invalid Account MSG=invalid account
> > >>>>>>>> I am specifying the same TG-account in my
> > >>>>>>> site-file
> > >>>>>>>> for the gram4 run that fails, as in the
> > >>> site-file
> > >>>>>>> for
> > >>>>>>>> the pre-ws job that suceeds. This is the
> > same
> > >>>>>>> project,
> > >>>>>>>> TG-MCA01S018, that is set in my
> > >>>>>>> .tg_default_project
> > >>>>>>>> file in ~kubal/ on the UC teragrid.
> > >>>>>>>> --- Ben Clifford <benc at hawaga.org.uk>
> > wrote:
> > >>>>>>>>> yeah, run that same without kickstart. the
> > >>> error
> > >>>>>>>>> reported is that
> > >>>>>>>>> kickstart didn't work right - but there's
> > >>>>>>> perhaps
> > >>>>>>>>> some underlying error.
> _____________________________________________________________________
> > >> _______________
> > >>>>>>>> Never miss a thing.  Make Yahoo your home
> > >>> page.
> > >>>>>>>> http://www.yahoo.com/r/hs
> > >> _______________
> > >>>>>> Be a better friend, newshound, and
> > >>>>>> know-it-all with Yahoo! Mobile.  Try it now.
> http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
> > >>> Swift-devel mailing list
> > >>> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> === message truncated ===
>       ____________________________________________________________________________________
> Looking for last minute shopping deals?
> Find them fast with Yahoo! Search.  http://tools.search.yahoo.com/newsearch/category.php?category=shopping
