[Swift-devel] Re: latest attempt with GRAM4
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Feb 12 14:37:18 CST 2008
You should probably remove the line completely.
Did you chose a default project on the login node with tgprojects?
On Tue, 2008-02-12 at 12:34 -0800, Mike Kubal wrote:
> I tried running with the account id removed from the
> sites.file as in the following line:
> <profile namespace="globus" key=""></profile>
> but received the same error.
> --- Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > Is this the same for pre-WS GRAM?
> > On Tue, 2008-02-12 at 14:20 -0600, Stuart Martin
> > wrote:
> > > that's right, qsub is used for PBS (and some
> > others too)
> > > bsub is LSF
> > > condor_q for condor
> > > -Stu
> > > On Feb 12, 2008, at Feb 12, 2:15 PM, Mihael
> > Hategan wrote:
> > > > On Tue, 2008-02-12 at 12:09 -0800, Mike Kubal
> > wrote:
> > > >> I'll give it a try.
> > > >> When using GRAM4, is qsub the method used to
> > > >> ultimately put the job in the queue?
> > > > Looks like it. I also believe it's the case with
> > pre-ws gram. Stu
> > > > may be
> > > > able to clarify.
> > > >> MikeK
> > > >>> While this doesn't solve the underlying
> > problem, it
> > > >>> may help you get
> > > >>> this to work: log into tg-login1.uc..., set
> > this
> > > >>> project as default,
> > > >>> then remove the project spec from the sites
> > file and
> > > >>> try again.
> > > >>> Mihael
> > > >>> On Tue, 2008-02-12 at 11:36 -0800, Mike Kubal
> > wrote:
> > > >>>> Yes, I believe you are right. The kickstart
> > > >>> message
> > > >>>> may be only a warning. After digging a little
> > > >>> deeper
> > > >>>> it appears the job is failing due to a
> > > >>> project/account
> > > >>>> id problem. I get the following error:
> > > >>>> Caused by:
> > > >>>>        The executable could not be started.,
> > > >>> qsub:
> > > >>>> Invalid Account MSG=invalid account
> > > >>>> I am specifying the same TG-account in my
> > > >>> site-file
> > > >>>> for the gram4 run that fails, as in the
> > site-file
> > > >>> for
> > > >>>> the pre-ws job that suceeds. This is the same
> > > >>> project,
> > > >>>> TG-MCA01S018, that is set in my
> > > >>> .tg_default_project
> > > >>>> file in ~kubal/ on the UC teragrid.
> > > >>>> --- Ben Clifford <benc at hawaga.org.uk> wrote:
> > > >>>>> yeah, run that same without kickstart. the
> > error
> > > >>>>> reported is that
> > > >>>>> kickstart didn't work right - but there's
> > > >>> perhaps
> > > >>>>> some underlying error.
> ____________________________________________________________________________________
> > > >>>> Never miss a thing.  Make Yahoo your home
> > page.
> > > >>>> http://www.yahoo.com/r/hs
> > > >> Be a better friend, newshound, and
> > > >> know-it-all with Yahoo! Mobile.  Try it now.
> http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> Looking for last minute shopping deals?
> Find them fast with Yahoo! Search.  http://tools.search.yahoo.com/newsearch/category.php?category=shopping
