[Swift-devel] Re: latest attempt with GRAM4
    Mike Kubal
    mikekubal at yahoo.com
    Tue Feb 12 14:34:28 CST 2008
I tried running with the account id removed from the
sites.file as in the following line:
<profile namespace="globus" key=""></profile>
but received the same error.
--- Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Is this the same for pre-WS GRAM?
> On Tue, 2008-02-12 at 14:20 -0600, Stuart Martin
> wrote:
> > that's right, qsub is used for PBS (and some
> others too)
> > bsub is LSF
> > condor_q for condor
> > -Stu
> > On Feb 12, 2008, at Feb 12, 2:15 PM, Mihael
> Hategan wrote:
> > > On Tue, 2008-02-12 at 12:09 -0800, Mike Kubal
> wrote:
> > >> I'll give it a try.
> > >> When using GRAM4, is qsub the method used to
> > >> ultimately put the job in the queue?
> > > Looks like it. I also believe it's the case with
> pre-ws gram. Stu
> > > may be
> > > able to clarify.
> > >> MikeK
> > >>> While this doesn't solve the underlying
> problem, it
> > >>> may help you get
> > >>> this to work: log into tg-login1.uc..., set
> this
> > >>> project as default,
> > >>> then remove the project spec from the sites
> file and
> > >>> try again.
> > >>> Mihael
> > >>> On Tue, 2008-02-12 at 11:36 -0800, Mike Kubal
> wrote:
> > >>>> Yes, I believe you are right. The kickstart
> > >>> message
> > >>>> may be only a warning. After digging a little
> > >>> deeper
> > >>>> it appears the job is failing due to a
> > >>> project/account
> > >>>> id problem. I get the following error:
> > >>>> Caused by:
> > >>>>        The executable could not be started.,
> > >>> qsub:
> > >>>> Invalid Account MSG=invalid account
> > >>>> I am specifying the same TG-account in my
> > >>> site-file
> > >>>> for the gram4 run that fails, as in the
> site-file
> > >>> for
> > >>>> the pre-ws job that suceeds. This is the same
> > >>> project,
> > >>>> TG-MCA01S018, that is set in my
> > >>> .tg_default_project
> > >>>> file in ~kubal/ on the UC teragrid.
> > >>>> --- Ben Clifford <benc at hawaga.org.uk> wrote:
> > >>>>> yeah, run that same without kickstart. the
> error
> > >>>>> reported is that
> > >>>>> kickstart didn't work right - but there's
> > >>> perhaps
> > >>>>> some underlying error.
____________________________________________________________________________________
> > >>>> Never miss a thing.  Make Yahoo your home
> page.
> > >>>> http://www.yahoo.com/r/hs
> > >> Be a better friend, newshound, and
> > >> know-it-all with Yahoo! Mobile.  Try it now.
http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Looking for last minute shopping deals?
Find them fast with Yahoo! Search.  http://tools.search.yahoo.com/newsearch/category.php?category=shopping
