[Swift-devel] Re: latest attempt with GRAM4
Stuart Martin
smartin at mcs.anl.gov
Tue Feb 12 14:26:44 CST 2008
Yes. Both versions use the *same* perl scripts to submit jobs.
On Feb 12, 2008, at Feb 12, 2:23 PM, Mihael Hategan wrote:
> Is this the same for pre-WS GRAM?
> On Tue, 2008-02-12 at 14:20 -0600, Stuart Martin wrote:
>> that's right, qsub is used for PBS (and some others too)
>> bsub is LSF
>> condor_q for condor
>> -Stu
>> On Feb 12, 2008, at Feb 12, 2:15 PM, Mihael Hategan wrote:
>>> On Tue, 2008-02-12 at 12:09 -0800, Mike Kubal wrote:
>>>> I'll give it a try.
>>>> When using GRAM4, is qsub the method used to
>>>> ultimately put the job in the queue?
>>> Looks like it. I also believe it's the case with pre-ws gram. Stu
>>> may be
>>> able to clarify.
>>>> MikeK
>>>> --- Mihael Hategan <hategan at mcs.anl.gov> wrote:
>>>>> While this doesn't solve the underlying problem, it
>>>>> may help you get
>>>>> this to work: log into tg-login1.uc..., set this
>>>>> project as default,
>>>>> then remove the project spec from the sites file and
>>>>> try again.
>>>>> Mihael
>>>>> On Tue, 2008-02-12 at 11:36 -0800, Mike Kubal wrote:
>>>>>> Yes, I believe you are right. The kickstart
>>>>> message
>>>>>> may be only a warning. After digging a little
>>>>> deeper
>>>>>> it appears the job is failing due to a
>>>>> project/account
>>>>>> id problem. I get the following error:
>>>>>> Caused by:
>>>>>> The executable could not be started.,
>>>>> qsub:
>>>>>> Invalid Account MSG=invalid account
>>>>>> I am specifying the same TG-account in my
>>>>> site-file
>>>>>> for the gram4 run that fails, as in the site-file
>>>>> for
>>>>>> the pre-ws job that suceeds. This is the same
>>>>> project,
>>>>>> TG-MCA01S018, that is set in my
>>>>> .tg_default_project
>>>>>> file in ~kubal/ on the UC teragrid.
>>>>>> --- Ben Clifford <benc at hawaga.org.uk> wrote:
>>>>>>> yeah, run that same without kickstart. the error
>>>>>>> reported is that
>>>>>>> kickstart didn't work right - but there's
>>>>> perhaps
>>>>>>> some underlying error.
>>>> ____________________________________________________________________________________
>>>>>> Never miss a thing. Make Yahoo your home page.
>>>>>> http://www.yahoo.com/r/hs
>>>> Be a better friend, newshound, and
>>>> know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
