[Swift-devel] Re: latest attempt with GRAM4
Mihael Hategan hategan at mcs.anl.gov
Tue Feb 12 14:23:22 CST 2008
Is this the same for pre-WS GRAM?
On Tue, 2008-02-12 at 14:20 -0600, Stuart Martin wrote:
> that's right, qsub is used for PBS (and some others too)
> bsub is LSF
> condor_q for condor
> -Stu
> On Feb 12, 2008, at Feb 12, 2:15 PM, Mihael Hategan wrote:
> > On Tue, 2008-02-12 at 12:09 -0800, Mike Kubal wrote:
> >> I'll give it a try.
> >> When using GRAM4, is qsub the method used to
> >> ultimately put the job in the queue?
> > Looks like it. I also believe it's the case with pre-ws gram. Stu
> > may be
> > able to clarify.
> >> MikeK
> >> --- Mihael Hategan <hategan at mcs.anl.gov> wrote:
> >>> While this doesn't solve the underlying problem, it
> >>> may help you get
> >>> this to work: log into tg-login1.uc..., set this
> >>> project as default,
> >>> then remove the project spec from the sites file and
> >>> try again.
> >>> Mihael
> >>> On Tue, 2008-02-12 at 11:36 -0800, Mike Kubal wrote:
> >>>> Yes, I believe you are right. The kickstart
> >>> message
> >>>> may be only a warning. After digging a little
> >>> deeper
> >>>> it appears the job is failing due to a
> >>> project/account
> >>>> id problem. I get the following error:
> >>>> Caused by:
> >>>>        The executable could not be started.,
> >>> qsub:
> >>>> Invalid Account MSG=invalid account
> >>>> I am specifying the same TG-account in my
> >>> site-file
> >>>> for the gram4 run that fails, as in the site-file
> >>> for
> >>>> the pre-ws job that suceeds. This is the same
> >>> project,
> >>>> TG-MCA01S018, that is set in my
> >>> .tg_default_project
> >>>> file in ~kubal/ on the UC teragrid.
> >>>> --- Ben Clifford <benc at hawaga.org.uk> wrote:
> >>>>> yeah, run that same without kickstart. the error
> >>>>> reported is that
> >>>>> kickstart didn't work right - but there's
> >>> perhaps
> >>>>> some underlying error.
> >> ____________________________________________________________________________________
> >>>> Never miss a thing.  Make Yahoo your home page.
> >>>> http://www.yahoo.com/r/hs
> >> Be a better friend, newshound, and
> >> know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
