[Swift-devel] Re: latest attempt with GRAM4
Stuart Martin smartin at mcs.anl.gov
Tue Feb 12 14:20:39 CST 2008
that's right, qsub is used for PBS (and some others too)
bsub is LSF
condor_q for condor
-Stu
On Feb 12, 2008, at Feb 12, 2:15 PM, Mihael Hategan wrote:
> On Tue, 2008-02-12 at 12:09 -0800, Mike Kubal wrote:
>> I'll give it a try.
>> When using GRAM4, is qsub the method used to
>> ultimately put the job in the queue?
> Looks like it. I also believe it's the case with pre-ws gram. Stu
> may be
> able to clarify.
>> MikeK
>> --- Mihael Hategan <hategan at mcs.anl.gov> wrote:
>>> While this doesn't solve the underlying problem, it
>>> may help you get
>>> this to work: log into tg-login1.uc..., set this
>>> project as default,
>>> then remove the project spec from the sites file and
>>> try again.
>>> Mihael
>>> On Tue, 2008-02-12 at 11:36 -0800, Mike Kubal wrote:
>>>> Yes, I believe you are right. The kickstart
>>> message
>>>> may be only a warning. After digging a little
>>> deeper
>>>> it appears the job is failing due to a
>>> project/account
>>>> id problem. I get the following error:
>>>> Caused by:
>>>>        The executable could not be started.,
>>> qsub:
>>>> Invalid Account MSG=invalid account
>>>> I am specifying the same TG-account in my
>>> site-file
>>>> for the gram4 run that fails, as in the site-file
>>> for
>>>> the pre-ws job that suceeds. This is the same
>>> project,
>>>> TG-MCA01S018, that is set in my
>>> .tg_default_project
>>>> file in ~kubal/ on the UC teragrid.
>>>> --- Ben Clifford <benc at hawaga.org.uk> wrote:
>>>>> yeah, run that same without kickstart. the error
>>>>> reported is that
>>>>> kickstart didn't work right - but there's
>>> perhaps
>>>>> some underlying error.
>> ____________________________________________________________________________________
>>>> Never miss a thing.  Make Yahoo your home page.
>>>> http://www.yahoo.com/r/hs
>> Be a better friend, newshound, and
>> know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
