[Swift-devel] Re: latest attempt with GRAM4
Mihael Hategan hategan at mcs.anl.gov
Tue Feb 12 14:15:06 CST 2008
On Tue, 2008-02-12 at 12:09 -0800, Mike Kubal wrote:
> I'll give it a try.
> When using GRAM4, is qsub the method used to
> ultimately put the job in the queue?
Looks like it. I also believe it's the case with pre-ws gram. Stu may be
able to clarify.
> MikeK
> --- Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > While this doesn't solve the underlying problem, it
> > may help you get
> > this to work: log into tg-login1.uc..., set this
> > project as default,
> > then remove the project spec from the sites file and
> > try again.
> > Mihael
> > On Tue, 2008-02-12 at 11:36 -0800, Mike Kubal wrote:
> > > Yes, I believe you are right. The kickstart
> > message
> > > may be only a warning. After digging a little
> > deeper
> > > it appears the job is failing due to a
> > project/account
> > > id problem. I get the following error:
> > > Caused by:
> > >         The executable could not be started.,
> > qsub:
> > > Invalid Account MSG=invalid account
> > > I am specifying the same TG-account in my
> > site-file
> > > for the gram4 run that fails, as in the site-file
> > for
> > > the pre-ws job that suceeds. This is the same
> > project,
> > > TG-MCA01S018, that is set in my
> > .tg_default_project
> > > file in ~kubal/ on the UC teragrid.
> > > --- Ben Clifford <benc at hawaga.org.uk> wrote:
> > > > yeah, run that same without kickstart. the error
> > > > reported is that
> > > > kickstart didn't work right - but there's
> > perhaps
> > > > some underlying error.
> ____________________________________________________________________________________
> > > Never miss a thing.  Make Yahoo your home page.
> > > http://www.yahoo.com/r/hs
> Be a better friend, newshound, and
> know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
