[Swift-devel] Re: latest attempt with GRAM4
    Mike Kubal
    mikekubal at yahoo.com
    Tue Feb 12 14:09:17 CST 2008
I'll give it a try.
When using GRAM4, is qsub the method used to
ultimately put the job in the queue?
MikeK
--- Mihael Hategan <hategan at mcs.anl.gov> wrote:
> While this doesn't solve the underlying problem, it
> may help you get
> this to work: log into tg-login1.uc..., set this
> project as default,
> then remove the project spec from the sites file and
> try again.
> Mihael
> On Tue, 2008-02-12 at 11:36 -0800, Mike Kubal wrote:
> > Yes, I believe you are right. The kickstart
> message
> > may be only a warning. After digging a little
> deeper
> > it appears the job is failing due to a
> project/account
> > id problem. I get the following error:
> > Caused by:
> >         The executable could not be started.,
> qsub:
> > Invalid Account MSG=invalid account
> > I am specifying the same TG-account in my
> site-file
> > for the gram4 run that fails, as in the site-file
> for
> > the pre-ws job that suceeds. This is the same
> project,
> > TG-MCA01S018, that is set in my
> .tg_default_project
> > file in ~kubal/ on the UC teragrid.
> > --- Ben Clifford <benc at hawaga.org.uk> wrote:
> > > yeah, run that same without kickstart. the error
> > > reported is that
> > > kickstart didn't work right - but there's
> perhaps
> > > some underlying error.
____________________________________________________________________________________
> > Never miss a thing.  Make Yahoo your home page.
> > http://www.yahoo.com/r/hs
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
