[Swift-devel] Re: latest attempt with GRAM4
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Feb 12 13:45:02 CST 2008
While this doesn't solve the underlying problem, it may help you get
this to work: log into tg-login1.uc..., set this project as default,
then remove the project spec from the sites file and try again.
Mihael
On Tue, 2008-02-12 at 11:36 -0800, Mike Kubal wrote:
> Yes, I believe you are right. The kickstart message
> may be only a warning. After digging a little deeper
> it appears the job is failing due to a project/account
> id problem. I get the following error:
> Caused by:
>         The executable could not be started., qsub:
> Invalid Account MSG=invalid account
> I am specifying the same TG-account in my site-file
> for the gram4 run that fails, as in the site-file for
> the pre-ws job that suceeds. This is the same project,
> TG-MCA01S018, that is set in my .tg_default_project
> file in ~kubal/ on the UC teragrid.
> --- Ben Clifford <benc at hawaga.org.uk> wrote:
> > yeah, run that same without kickstart. the error
> > reported is that
> > kickstart didn't work right - but there's perhaps
> > some underlying error.
>       ____________________________________________________________________________________
> Never miss a thing.  Make Yahoo your home page.
> http://www.yahoo.com/r/hs
