[Swift-devel] Re: latest attempt with GRAM4
    Mike Kubal
    mikekubal at yahoo.com
    Tue Feb 12 13:36:20 CST 2008
Yes, I believe you are right. The kickstart message
may be only a warning. After digging a little deeper
it appears the job is failing due to a project/account
id problem. I get the following error:
Caused by:
        The executable could not be started., qsub:
Invalid Account MSG=invalid account
I am specifying the same TG-account in my site-file
for the gram4 run that fails, as in the site-file for
the pre-ws job that suceeds. This is the same project,
TG-MCA01S018, that is set in my .tg_default_project
file in ~kubal/ on the UC teragrid.
--- Ben Clifford <benc at hawaga.org.uk> wrote:
> yeah, run that same without kickstart. the error
> reported is that
> kickstart didn't work right - but there's perhaps
> some underlying error.
      ____________________________________________________________________________________
Never miss a thing.  Make Yahoo your home page.
http://www.yahoo.com/r/hs
