[Swift-devel] cog r1871
    Ben Clifford
    benc at hawaga.org.uk
    Tue Feb 12 06:47:23 CST 2008
On Mon, 11 Feb 2008, feller at mcs.anl.gov wrote:
> My fault, not the ObjectSerializers one.
> You submitted in batch-mode?
The final cleanup job that failed is in batch mode, yes. Its the only one
submitted that way.
> The attached jar should fix that.
With your new jar, I no longer get that error. I did once get the below
stack trace, though execution appeared to continue. It hasn't happened a
second time or third time on running the same tests.
touch started
Unable to destroy remote service for task urn:0-1-1202817892228
java.lang.NullPointerException
        at
org.globus.exec.generated.service.ManagedJobServiceAddressingLocator.getManagedJobPortTypePort(ManagedJobServiceAddressingLocator.java:12)
        at
org.globus.exec.utils.client.ManagedJobClientHelper.getPort(ManagedJobClientHelper.java:32)
        at org.globus.exec.client.GramJob.destroy(GramJob.java:1303)
        at
org.globus.cog.abstraction.impl.execution.gt4_0_0.JobSubmissionTaskHandler.cleanup(JobSubmissionTaskHandler.java:431)
        at
org.globus.cog.abstraction.impl.execution.gt4_0_0.JobSubmissionTaskHandler.stateChanged(JobSubmissionTaskHandler.java:397)
        at org.globus.exec.client.GramJob.setState(GramJob.java:321)
        at org.globus.exec.client.GramJob.deliver(GramJob.java:1677)
        at
org.globus.wsrf.impl.notification.NotificationConsumerProvider.notify(NotificationConsumerProvider.java:126)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
        at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
        at java.lang.reflect.Method.invoke(Method.java:585)
        at
org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:384)
        at
org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:281)
        at
org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:319)
        at
org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
        at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
        at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
        at
org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:450)
        at org.apache.axis.server.AxisServer.invoke(AxisServer.java:285)
        at
org.globus.wsrf.container.ServiceThread.doPost(ServiceThread.java:664)
        at
org.globus.wsrf.container.ServiceThread.process(ServiceThread.java:382)
        at
org.globus.wsrf.container.GSIServiceThread.process(GSIServiceThread.java:147)
        at
org.globus.wsrf.container.ServiceThread.run(ServiceThread.java:291)
touch completed
