[Swift-devel] cog r1871
    feller at mcs.anl.gov
    Mon Feb 11 23:28:05 CST 2008
My fault, not the ObjectSerializers one.
You submitted in batch-mode?
The attached jar should fix that.
Hope the java version is fine.
Martin
> Martin?
> On Mon, 2008-02-11 at 22:50 +0000, Ben Clifford wrote:
>> I'm seeing repeatable cleanup errors like the below. The workflows run
>> to
>> completion, though.
>> RunID: 20080211-2248-rsqe1da0
>> cat started
>> cat completed
>> The following warnings have occurred:
>> 1. Cleanup on tguc failed
>> Caused by:
>>         Cannot submit job: null
>> Caused by:
>>         java.lang.NullPointerException
>>         at
>> org.globus.wsrf.encoding.ObjectSerializer.clone(ObjectSerializer.java:211)
>>         at
>> org.globus.exec.client.GramJob.createJobEndpoint(GramJob.java:970)
>>         at org.globus.exec.client.GramJob.submit(GramJob.java:447)
>>         at
>> org.globus.cog.abstraction.impl.execution.gt4_0_0.JobSubmissionTaskHandler.submit(JobSubmissionTaskHandler.java:189)
>>         at
>> org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:54)
>>         at
>> org.globus.cog.karajan.scheduler.submitQueue.NonBlockingSubmit.run(NonBlockingSubmit.java:86)
>>         at
>> edu.emory.mathcs.backport.java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:431)
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20080211/219b413f/attachment.obj>
