[Swift-devel] cog r1871
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon Feb 11 17:46:42 CST 2008
Martin?
On Mon, 2008-02-11 at 22:50 +0000, Ben Clifford wrote:
> I'm seeing repeatable cleanup errors like the below. The workflows run to
> completion, though.
> RunID: 20080211-2248-rsqe1da0
> cat started
> cat completed
> The following warnings have occurred:
> 1. Cleanup on tguc failed
> Caused by:
>         Cannot submit job: null
> Caused by:
>         java.lang.NullPointerException
>         at
> org.globus.wsrf.encoding.ObjectSerializer.clone(ObjectSerializer.java:211)
>         at
> org.globus.exec.client.GramJob.createJobEndpoint(GramJob.java:970)
>         at org.globus.exec.client.GramJob.submit(GramJob.java:447)
>         at
> org.globus.cog.abstraction.impl.execution.gt4_0_0.JobSubmissionTaskHandler.submit(JobSubmissionTaskHandler.java:189)
>         at
> org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:54)
>         at
> org.globus.cog.karajan.scheduler.submitQueue.NonBlockingSubmit.run(NonBlockingSubmit.java:86)
>         at
> edu.emory.mathcs.backport.java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:431)
