[Swift-devel] ws-gram tests
    Mihael Hategan
    hategan at mcs.anl.gov
    Fri Feb  8 09:33:43 CST 2008
I disabled the job throttle in this case. I also didn't consider
failures (restarts were at 0).
In the last run I got exactly one failure, but in some previous runs
(with 256 jobs) I got more. All that needs to be debugged.
On Fri, 2008-02-08 at 14:01 +0000, Ben Clifford wrote:
> some rough numbers in this space that I collected yesterday:
> I ran a 10000 (10^5) parallel jobs workflow on teraport using the PBS
> provider. It launched up to 401 jobs at once, as per the default config
> file. It took about 6h but ran ok. I didn't keep any other statistics,
> though - just set it going in the morning and let it run. That's a
> throughput of about one job every couple of seconds.
> My laptop can do about 5000 of the same kind of job through the fork
> provider, running at most 2 jobs at once, in about 15 minutes.
