[Swift-devel] ws-gram tests
    Ian Foster
    foster at mcs.anl.gov
    Fri Feb  8 09:19:21 CST 2008
Mihael:
That's great, thanks!
Ian.
Mihael Hategan wrote:
> I did a 1024 job run today with ws-gram.
> I painted the results here:
> http://www-unix.mcs.anl.gov/~hategan/s/g.html
> Seems like client memory per job is about 370k. Which is quite a lot.
> What kinda worries me is that it doesn't seem to go down after the jobs
> are done, so maybe there's a memory leak, or maybe the garbage collector
> doesn't do any major collections. I'll need to profile this to see
> exactly what we're talking about.
> The container memory is figured by looking at the process in /proc. It's
> total memory including shared libraries and things. But libraries take a
> fixed amount of space, so a fuzzy correlation can probably be made. It
> looks quite similar to the amount of memory eaten on the client side
> (per job).
> CPU-load-wise, WS-GRAM behaves. There is some work during the time the
> jobs are submitted, but the machine itself seems responsive. I have yet
> to plot the exact submission time for each job.
> So at this point I would recommend trying ws-gram as long as there
> aren't too many jobs involved (i.e. under 4000 parallel jobs), and while
> making sure the jvm has enough heap. More than that seems like a gamble.
> Mihael
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
