[Swift-devel] Re: Swift jobs on UC/ANL TG
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon Feb  4 14:45:06 CST 2008
For that to work, you'll need to fetch Swift from SVN.
You can find instructions on how to do that here:
http://www.ci.uchicago.edu/swift/downloads/index.php
Mihael
On Mon, 2008-02-04 at 18:44 +0000, Ben Clifford wrote:
> you can also try out gram4 as follows:
> * get swift r1609 from SVN
> * set a site entry like this:
> <pool handle="uc.teragrid.org" sysinfo="INTEL32::LINUX"
> gridlaunch="/home/wilde/vds/mystart">
>     <gridftp  url="gsiftp://tg-gridftp.uc.teragrid.org"
> storage="/home/benc" maj
> or="2" minor="2" />
>     <execution provider="gt4" jobmanager="PBS"
> url="tg-grid.uc.teragrid.org" />
>     <workdirectory >/home/benc</workdirectory>
>     <profile namespace="globus" key="project">TG-CCR080002N</profile>
> </pool>
> Change the project key to a project that you are on (or, if you have a
> default project, you can remove it).
> I've run this from from teraport submitting to TG-UC using the default
> load parameters and it has made it through 730 or so jobs of a 1000 node
> workflow without apparently excessive load (its still running - also I got
> some ftp failures, but job retry should handle those)
