[Swift-devel] Re: Swift jobs on UC/ANL TG
    Ben Clifford
    benc at hawaga.org.uk
    Mon Feb  4 13:27:31 CST 2008
On Mon, 4 Feb 2008, Ben Clifford wrote:
> I've run this from from teraport submitting to TG-UC using the default
> load parameters and it has made it through 730 or so jobs of a 1000 node
> workflow without apparently excessive load (its still running - also I got
> some ftp failures, but job retry should handle those)
actually, that run got stuck - it seems to have lost one job (as in, it
isn't in the PBS queue but Swift still thinks its in progress)
I'll look at that closer somewhat later.
