[Swift-devel] Re: Swift jobs on UC/ANL TG
Ben Clifford benc at hawaga.org.uk
Mon Feb 4 12:44:38 CST 2008
you can also try out gram4 as follows:
* get swift r1609 from SVN
* set a site entry like this:
<pool handle="uc.teragrid.org" sysinfo="INTEL32::LINUX"
gridlaunch="/home/wilde/vds/mystart">
    <gridftp  url="gsiftp://tg-gridftp.uc.teragrid.org"
storage="/home/benc" maj
or="2" minor="2" />
    <execution provider="gt4" jobmanager="PBS"
url="tg-grid.uc.teragrid.org" />
    <workdirectory >/home/benc</workdirectory>
    <profile namespace="globus" key="project">TG-CCR080002N</profile>
</pool>
Change the project key to a project that you are on (or, if you have a
default project, you can remove it).
I've run this from from teraport submitting to TG-UC using the default
load parameters and it has made it through 730 or so jobs of a 1000 node
workflow without apparently excessive load (its still running - also I got
some ftp failures, but job retry should handle those)
