[Swift-devel] throttle.score.job.transfer
    Mike Kubal
    mikekubal at yahoo.com
    Mon Feb  4 12:55:06 CST 2008
or I'll try Ben's r1609 approach, unless folks would
like a baseline.
--- Mike Kubal <mikekubal at yahoo.com> wrote:
> Unless there are any objections, I'd like to submit
> a
> maximum of 21 jobs to the UC -teragrid with the
> throttling thresholds limited to the following so a
> baseline metric could be established:
> throttle.submit = 2 (default 4)
> throttle.host.submit = 1 (default 2)
> throttle.score.job.factor = 1 (default 4)
> throttle.transfers = 2 (default 4)
> throttle.file.operations = 4 (default 8)
> Ti, I'll let you know as soon as I launch it.
> Depending on how this goes, I plan to try Ben's
> local
> PB approach next.
> Cheers,
> Mike
> --- Ben Clifford <benc at hawaga.org.uk> wrote:
> > On Mon, 4 Feb 2008, Mike Kubal wrote:
> > > I attempted to run a job with
> > > throttle.score.job.transfer of .5 and the job
> > failed
> > > with the following:
> > > Execution failed:
> > >         Could not convert value to number: .5
> > > Caused by:
> > >         For input string: ".5"
> > yeah, turns out its an integer only field. my bad
> > for telling you
> > otherwise.
____________________________________________________________________________________
> Never miss a thing.  Make Yahoo your home page.
> http://www.yahoo.com/r/hs
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
