[Swift-devel] throttle.score.job.transfer
Mike Kubal
mikekubal at yahoo.com
Mon Feb 4 12:49:23 CST 2008
Unless there are any objections, I'd like to submit a
maximum of 21 jobs to the UC -teragrid with the
throttling thresholds limited to the following so a
baseline metric could be established:
throttle.submit = 2 (default 4)
throttle.host.submit = 1 (default 2)
throttle.score.job.factor = 1 (default 4)
throttle.transfers = 2 (default 4)
throttle.file.operations = 4 (default 8)
Ti, I'll let you know as soon as I launch it.
Depending on how this goes, I plan to try Ben's local
PB approach next.
Cheers,
Mike
--- Ben Clifford <benc at hawaga.org.uk> wrote:
> On Mon, 4 Feb 2008, Mike Kubal wrote:
> > I attempted to run a job with
> > throttle.score.job.transfer of .5 and the job
> failed
> > with the following:
> > Execution failed:
> > Could not convert value to number: .5
> > Caused by:
> > For input string: ".5"
> yeah, turns out its an integer only field. my bad
> for telling you
> otherwise.
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
