[Swift-devel] ssh data provider
Mihael Hategan
hategan at mcs.anl.gov
Thu Dec 11 19:46:41 CST 2008
Have you installed the public key on ion-1?
On Thu, 2008-12-11 at 19:10 -0600, Zhao Zhang wrote:
> Then it failed
> zzhang at login6.surveyor:~/swift/test> ssh -v -o
> HostbasedAuthentication=no -l zzh
> ang -i /home/zzhang/.ssh/id_rsa ion-7
> OpenSSH_4.2p1, OpenSSL 0.9.8a 11 Oct 2005
> debug1: Reading configuration data /etc/ssh/ssh_config
> debug1: Applying options for *
> debug1: /etc/ssh/ssh_config line 25: Deprecated option
> "RhostsAuthentication"
> debug1: Connecting to ion-7 [172.16.3.7] port 22.
> debug1: Connection established.
> debug1: identity file /home/zzhang/.ssh/id_rsa type 1
> debug1: Remote protocol version 2.0, remote software version OpenSSH_4.2
> debug1: match: OpenSSH_4.2 pat OpenSSH*
> debug1: Enabling compatibility mode for protocol 2.0
> debug1: Local version string SSH-2.0-OpenSSH_4.2
> debug1: SSH2_MSG_KEXINIT sent
> debug1: SSH2_MSG_KEXINIT received
> debug1: kex: server->client aes128-cbc hmac-md5 none
> debug1: kex: client->server aes128-cbc hmac-md5 none
> debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(1024<1024<8192) sent
> debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
> debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
> debug1: expecting SSH2_MSG_KEX_DH_GEX_REPLY
> debug1: Host 'ion-7' is known and matches the RSA host key.
> debug1: Found key in /home/zzhang/.ssh/known_hosts:43
> debug1: ssh_rsa_verify: signature correct
> debug1: SSH2_MSG_NEWKEYS sent
> debug1: expecting SSH2_MSG_NEWKEYS
> debug1: SSH2_MSG_NEWKEYS received
> debug1: SSH2_MSG_SERVICE_REQUEST sent
> debug1: SSH2_MSG_SERVICE_ACCEPT received
> debug1: Authentications that can continue:
> publickey,keyboard-interactive,hostbased
> debug1: Next authentication method: publickey
> debug1: Offering public key: /home/zzhang/.ssh/id_rsa
> debug1: Next authentication method: keyboard-interactive
> debug1: No more authentication methods to try.
> Permission denied (publickey,keyboard-interactive,hostbased).
> Mihael Hategan wrote:
> > I looked at the ssh logs, and it seems like you're logging in using
> > hostbased authentication.
> > Try ssh -v -o HostBasedAuthenticatiosn=no -l zzhang
> > -i /home/zzhang/.ssh/id_rsa ion-1
> > Also, note that you misspelled "id_rsa": Warning: Identity
> > file /home/zzhang/.ssh/ir_rsa not accessible: No such
> > file or directory.
> > On Thu, 2008-12-11 at 18:51 -0600, Zhao Zhang wrote:
> >> Ha, you are right, i put a wrong log here.
> >> I rerun it, if failed with the following message.
> >> zzhang at login6.surveyor:~/swift/test> swift -sites.file ./sites.xml
> >> -tc.file ./tc.data first.swift
> >> Swift svn swift-r2334 (Swift modified locally) cog-r2216
> >> RunID: 20081211-1850-rcrr2fk0
> >> Progress:
> >> echo started
> >> Sorted: [bgp000:1,000.000(98.545):0/789 overload: 0]
> >> Sorted: [bgp000:999.590(98.544):0/789 overload: 0]
> >> Sorted: [bgp000:999.180(98.544):0/789 overload: 0]
> >> echo failed
> >> Execution failed:
> >> Could not initialize shared directory on bgp000
> >> Caused by:
> >> org.globus.cog.abstraction.impl.file.FileResourceException:
> >> Error while communicating with the SSH server on 172.16.3.7:22
> >> Caused by:
> >> Public Key Authentication failed
> >> zhao
> >>> On Thu, 2008-12-11 at 18:38 -0600, Zhao Zhang wrote:
> >>>> sure, it is 172.16.3.6.passphrase=
> >>> I don't believe you. Can you paste the file?
> >>>>> On Thu, 2008-12-11 at 18:30 -0600, Zhao Zhang wrote:
> >>>>>> Hi, Mihael
> >>>>>> If I put .passphrase= there, I got this:
> >>>>> With the IP address before .passphrase, of course. I.e.
