[Swift-devel] ssh data provider
    Zhao Zhang
    zhaozhang at uchicago.edu
    Thu Dec 11 20:00:10 CST 2008
nope, we don't need to since ssh works for us. Besides, I have no idea
where the ssh on IO nodes saves the public key.
zhao
Mihael Hategan wrote:
> Have you installed the public key on ion-1?
> On Thu, 2008-12-11 at 19:10 -0600, Zhao Zhang wrote:
>> Then it failed
>> zzhang at login6.surveyor:~/swift/test> ssh -v -o
>> HostbasedAuthentication=no -l zzh
>> ang -i /home/zzhang/.ssh/id_rsa ion-7
>> OpenSSH_4.2p1, OpenSSL 0.9.8a 11 Oct 2005
>> debug1: Reading configuration data /etc/ssh/ssh_config
>> debug1: Applying options for *
>> debug1: /etc/ssh/ssh_config line 25: Deprecated option
>> "RhostsAuthentication"
>> debug1: Connecting to ion-7 [172.16.3.7] port 22.
>> debug1: Connection established.
>> debug1: identity file /home/zzhang/.ssh/id_rsa type 1
>> debug1: Remote protocol version 2.0, remote software version OpenSSH_4.2
>> debug1: match: OpenSSH_4.2 pat OpenSSH*
>> debug1: Enabling compatibility mode for protocol 2.0
>> debug1: Local version string SSH-2.0-OpenSSH_4.2
>> debug1: SSH2_MSG_KEXINIT sent
>> debug1: SSH2_MSG_KEXINIT received
>> debug1: kex: server->client aes128-cbc hmac-md5 none
>> debug1: kex: client->server aes128-cbc hmac-md5 none
>> debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(1024<1024<8192) sent
>> debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
>> debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
>> debug1: expecting SSH2_MSG_KEX_DH_GEX_REPLY
>> debug1: Host 'ion-7' is known and matches the RSA host key.
>> debug1: Found key in /home/zzhang/.ssh/known_hosts:43
>> debug1: ssh_rsa_verify: signature correct
>> debug1: SSH2_MSG_NEWKEYS sent
>> debug1: expecting SSH2_MSG_NEWKEYS
>> debug1: SSH2_MSG_NEWKEYS received
>> debug1: SSH2_MSG_SERVICE_REQUEST sent
>> debug1: SSH2_MSG_SERVICE_ACCEPT received
>> debug1: Authentications that can continue:
>> publickey,keyboard-interactive,hostbased
>> debug1: Next authentication method: publickey
>> debug1: Offering public key: /home/zzhang/.ssh/id_rsa
>> debug1: Next authentication method: keyboard-interactive
>> debug1: No more authentication methods to try.
>> Permission denied (publickey,keyboard-interactive,hostbased).
>>> I looked at the ssh logs, and it seems like you're logging in using
>>> hostbased authentication.
>>> Try ssh -v -o HostBasedAuthenticatiosn=no -l zzhang
>>> -i /home/zzhang/.ssh/id_rsa ion-1
>>> Also, note that you misspelled "id_rsa": Warning: Identity
>>> file /home/zzhang/.ssh/ir_rsa not accessible: No such
>>> file or directory.
>>> On Thu, 2008-12-11 at 18:51 -0600, Zhao Zhang wrote:
>>>> Ha, you are right, i put a wrong log here.
>>>> I rerun it, if failed with the following message.
>>>> zzhang at login6.surveyor:~/swift/test> swift -sites.file ./sites.xml
>>>> -tc.file ./tc.data first.swift
>>>> Swift svn swift-r2334 (Swift modified locally) cog-r2216
>>>> RunID: 20081211-1850-rcrr2fk0
>>>> Progress:
>>>> echo started
>>>> Sorted: [bgp000:1,000.000(98.545):0/789 overload: 0]
>>>> Sorted: [bgp000:999.590(98.544):0/789 overload: 0]
>>>> Sorted: [bgp000:999.180(98.544):0/789 overload: 0]
>>>> echo failed
>>>> Execution failed:
>>>>         Could not initialize shared directory on bgp000
>>>> Caused by:
>>>>         org.globus.cog.abstraction.impl.file.FileResourceException:
>>>> Error while communicating with the SSH server on 172.16.3.7:22
>>>> Caused by:
>>>>         Public Key Authentication failed
>>>> zhao
>>>>> On Thu, 2008-12-11 at 18:38 -0600, Zhao Zhang wrote:
>>>>>> sure, it is 172.16.3.6.passphrase=
>>>>> I don't believe you. Can you paste the file?
>>>>>>> On Thu, 2008-12-11 at 18:30 -0600, Zhao Zhang wrote:
>>>>>>>> Hi, Mihael
>>>>>>>> If I put .passphrase= there, I got this:
>>>>>>> With the IP address before .passphrase, of course. I.e.
