[Swift-devel] ssh data provider
Zhao Zhang
zhaozhang at uchicago.edu
Thu Dec 11 19:10:32 CST 2008
Then it failed
zzhang at login6.surveyor:~/swift/test> ssh -v -o
HostbasedAuthentication=no -l zzh
ang -i /home/zzhang/.ssh/id_rsa ion-7
OpenSSH_4.2p1, OpenSSL 0.9.8a 11 Oct 2005
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: Applying options for *
debug1: /etc/ssh/ssh_config line 25: Deprecated option
"RhostsAuthentication"
debug1: Connecting to ion-7 [172.16.3.7] port 22.
debug1: Connection established.
debug1: identity file /home/zzhang/.ssh/id_rsa type 1
debug1: Remote protocol version 2.0, remote software version OpenSSH_4.2
debug1: match: OpenSSH_4.2 pat OpenSSH*
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_4.2
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: server->client aes128-cbc hmac-md5 none
debug1: kex: client->server aes128-cbc hmac-md5 none
debug1: SSH2_MSG_KEX_DH_GEX_REQUEST(1024<1024<8192) sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_GROUP
debug1: SSH2_MSG_KEX_DH_GEX_INIT sent
debug1: expecting SSH2_MSG_KEX_DH_GEX_REPLY
debug1: Host 'ion-7' is known and matches the RSA host key.
debug1: Found key in /home/zzhang/.ssh/known_hosts:43
debug1: ssh_rsa_verify: signature correct
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue:
publickey,keyboard-interactive,hostbased
debug1: Next authentication method: publickey
debug1: Offering public key: /home/zzhang/.ssh/id_rsa
debug1: Next authentication method: keyboard-interactive
debug1: No more authentication methods to try.
Permission denied (publickey,keyboard-interactive,hostbased).
Mihael Hategan wrote:
> I looked at the ssh logs, and it seems like you're logging in using
> hostbased authentication.
> Try ssh -v -o HostBasedAuthenticatiosn=no -l zzhang
> -i /home/zzhang/.ssh/id_rsa ion-1
> Also, note that you misspelled "id_rsa": Warning: Identity
> file /home/zzhang/.ssh/ir_rsa not accessible: No such
> file or directory.
> On Thu, 2008-12-11 at 18:51 -0600, Zhao Zhang wrote:
>> Ha, you are right, i put a wrong log here.
>> I rerun it, if failed with the following message.
>> zzhang at login6.surveyor:~/swift/test> swift -sites.file ./sites.xml
>> -tc.file ./tc.data first.swift
>> Swift svn swift-r2334 (Swift modified locally) cog-r2216
>> RunID: 20081211-1850-rcrr2fk0
>> Progress:
>> echo started
>> Sorted: [bgp000:1,000.000(98.545):0/789 overload: 0]
>> Sorted: [bgp000:999.590(98.544):0/789 overload: 0]
>> Sorted: [bgp000:999.180(98.544):0/789 overload: 0]
>> echo failed
>> Execution failed:
>> Could not initialize shared directory on bgp000
>> Caused by:
>> org.globus.cog.abstraction.impl.file.FileResourceException:
>> Error while communicating with the SSH server on 172.16.3.7:22
>> Caused by:
>> Public Key Authentication failed
>> zhao
>>> On Thu, 2008-12-11 at 18:38 -0600, Zhao Zhang wrote:
>>>> sure, it is 172.16.3.6.passphrase=
>>> I don't believe you. Can you paste the file?
>>>>> On Thu, 2008-12-11 at 18:30 -0600, Zhao Zhang wrote:
>>>>>> Hi, Mihael
>>>>>> If I put .passphrase= there, I got this:
>>>>> With the IP address before .passphrase, of course. I.e.
