[Swift-devel] ssh data provider
Mihael Hategan hategan at mcs.anl.gov
Thu Dec 11 19:02:27 CST 2008
I looked at the ssh logs, and it seems like you're logging in using
hostbased authentication.
Try ssh -v -o HostBasedAuthenticatiosn=no -l zzhang
-i /home/zzhang/.ssh/id_rsa ion-1
Also, note that you misspelled "id_rsa": Warning: Identity
file /home/zzhang/.ssh/ir_rsa not accessible: No such
file or directory.
On Thu, 2008-12-11 at 18:51 -0600, Zhao Zhang wrote:
> Ha, you are right, i put a wrong log here.
> I rerun it, if failed with the following message.
> zzhang at login6.surveyor:~/swift/test> swift -sites.file ./sites.xml
> -tc.file ./tc.data first.swift
> Swift svn swift-r2334 (Swift modified locally) cog-r2216
> RunID: 20081211-1850-rcrr2fk0
> Progress:
> echo started
> Sorted: [bgp000:1,000.000(98.545):0/789 overload: 0]
> Sorted: [bgp000:999.590(98.544):0/789 overload: 0]
> Sorted: [bgp000:999.180(98.544):0/789 overload: 0]
> echo failed
> Execution failed:
>         Could not initialize shared directory on bgp000
> Caused by:
>         org.globus.cog.abstraction.impl.file.FileResourceException:
> Error while communicating with the SSH server on 172.16.3.7:22
> Caused by:
>         Public Key Authentication failed
> zhao
> Mihael Hategan wrote:
> > On Thu, 2008-12-11 at 18:38 -0600, Zhao Zhang wrote:
> >> sure, it is 172.16.3.6.passphrase=
> > I don't believe you. Can you paste the file?
> >>> On Thu, 2008-12-11 at 18:30 -0600, Zhao Zhang wrote:
> >>>> Hi, Mihael
> >>>> If I put .passphrase= there, I got this:
> >>> With the IP address before .passphrase, of course. I.e.
