[Swift-devel] ssh data provider
    Zhao Zhang
    zhaozhang at uchicago.edu
    Thu Dec 11 18:51:28 CST 2008
Ha, you are right, i put a wrong log here.
I rerun it, if failed with the following message.
zzhang at login6.surveyor:~/swift/test> swift -sites.file ./sites.xml
-tc.file ./tc.data first.swift
Swift svn swift-r2334 (Swift modified locally) cog-r2216
RunID: 20081211-1850-rcrr2fk0
Progress:
echo started
Sorted: [bgp000:1,000.000(98.545):0/789 overload: 0]
Sorted: [bgp000:999.590(98.544):0/789 overload: 0]
Sorted: [bgp000:999.180(98.544):0/789 overload: 0]
echo failed
Execution failed:
        Could not initialize shared directory on bgp000
Caused by:
        org.globus.cog.abstraction.impl.file.FileResourceException:
Error while communicating with the SSH server on 172.16.3.7:22
Caused by:
        Public Key Authentication failed
zhao
Mihael Hategan wrote:
> On Thu, 2008-12-11 at 18:38 -0600, Zhao Zhang wrote:
>> sure, it is 172.16.3.6.passphrase=
> I don't believe you. Can you paste the file?
>>> On Thu, 2008-12-11 at 18:30 -0600, Zhao Zhang wrote:
>>>> Hi, Mihael
>>>> If I put .passphrase= there, I got this:
>>> With the IP address before .passphrase, of course. I.e.
