[Swift-devel] [Fwd: Re: error communicating with Abe's GridFTP	server ]
    help at teragrid.org
    Thu Aug 28 17:03:43 CDT 2008
(Concerning ticket No. 161020)
Sorry, forgot to CC those on the cc list.
__________Original Message__________
Date: Aug 28 2008 5:01PM
  To: mikekubal at yahoo.com
Subj: Re: error communicating with Abe's GridFTP server
Hello Mike,
We also got an errors when just trying to open a simple connection with uberftp.
We will ask the our Grid Services Admin to take a look and notify you when we
have news.
-Weddie
Weddie Jackson
NCSA Consulting Services
Mike Kubal <mikekubal at yahoo.com> writes:
>I get the following message when trying to run a swift job from the machines
at the CI (communicado and bridled) on NCSA's Abe:
>Execution failed:
>        Could not initialize shared directory on abe
>Caused by:
>        org.globus.cog.abstraction.impl.file.FileResourceException: Error
communicating with the GridFTP server
>Caused by:
>        Server refused performing the request. Custom message: Bad password.
(error code 1) [Nested exception message:  Custom message: Unexpected reply:
530-Login incorrect. : IPC connection failed.
>Are there any known webservice or other issues with Abe's GridFTP server?
>The gatekeeper appears to be up, when I run:
>globus-job-run grid-abe.ncsa.teragrid.org /bin/hostname
>It returns:
>abe1196.ncsa.uiuc.edu
>If I run:
>globus-job-run gsiftp://grid-ftp.abe.ncsa.teragrid.org hostname
>I get the following:
>GRAM Job submission failed because the connection to the server failed (check
host and port) (error code 12)
>In the past I have received similar error messages when my certificate at the
CI had not been updated, but the problem persists after an update.
>I get the same message running from communicado and bridled at the CI.
>Suggestions?
>Mike Kubal
