[Swift-devel] [Fwd: Re: error communicating with Abe's GridFTP	server ]
    help at teragrid.org
    Fri Aug 29 11:23:16 CDT 2008
(Concerning ticket No. 161020)
Hello Mike,
Our Grid Services Admins have stated that they believe that have resolved the
issue.
Can you try your job again(if you have not already done so) and let us know if
you are still seeing an issue?
(if you are still seeing an issue, it may be helpful to the Admins to know
exactly how your job is trying to communicate with gridftp-abe)
-Weddie
Weddie Jackson
NCSA Consulting Services
__________Original Message__________
Date: Aug 28 2008 5:01PM
  To: mikekubal at yahoo.com
Subj: Re: error communicating with Abe's GridFTP server
Hello Mike,
We also got an errors when just trying to open a simple connection with uberftp.
We will ask the our Grid Services Admin to take a look and notify you when we
have news.
-Weddie
Weddie Jackson
Mike Kubal <mikekubal at yahoo.com> writes:
>I get the following message when trying to run a swift job from the machines
at the CI (communicado and bridled) on NCSA's Abe:
>Execution failed:
>        Could not initialize shared directory on abe
>Caused by:
>        org.globus.cog.abstraction.impl.file.FileResourceException: Error
communicating with the GridFTP server
>Caused by:
>        Server refused performing the request. Custom message: Bad password.
(error code 1) [Nested exception message:  Custom message: Unexpected reply:
530-Login incorrect. : IPC connection failed.
>Are there any known webservice or other issues with Abe's GridFTP server?
>The gatekeeper appears to be up, when I run:
>globus-job-run grid-abe.ncsa.teragrid.org /bin/hostname
>It returns:
>abe1196.ncsa.uiuc.edu
>If I run:
>globus-job-run gsiftp://grid-ftp.abe.ncsa.teragrid.org hostname
>I get the following:
>GRAM Job submission failed because the connection to the server failed (check
host and port) (error code 12)
>In the past I have received similar error messages when my certificate at the
CI had not been updated, but the problem persists after an update.
>I get the same message running from communicado and bridled at the CI.
>Suggestions?
>Mike Kubal
