[Swift-devel] connection error
    Michael Wilde
    wilde at mcs.anl.gov
    Thu Aug  7 21:53:27 CDT 2008
Mike, I wonder if you can try communicado.ci.uchicago.edu?
It should require no change in any scripts, tools or procedures (I think).
I *think* that communicado's certs are up to date.
Its not clear yet that this is a host-cert problem, but thats worth a try.
What server were you trying to reach?  Can you test a simple
globus-job-run to it?
- Mike
On 8/7/08 8:42 PM, Mike Kubal wrote:
> Hi Ben,
> I have a feeling this is a certificate or CRL issue on the host machine
> (terminable at the CI), but perhaps you can tell for sure by examining
> the log, Pipeline_BoNT-20080807-1449-zm9x88ad.log . Nothing in the swift
> code or sites file has changed.
> Caused by:
>         Cannot submit job
> Caused by:
>         The connection to the server failed (check host and port)
> [Caused by: Connection refused]
> Progress:  Selecting site:1035 Executing:1 Failed:2 Failed but can retry:1
> I rsync'd over many logs from various stages of processing 4000 ligands
> against a target to your CI swift-log dir, including the one above.
> Thanks,
> MikeK
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
