[Swift-devel] Re: Another performance comparison of DOCK
    Zhao Zhang
    zhaozhang at uchicago.edu
    Sun Apr 13 17:58:55 CDT 2008
Hi, Mike
It is just a typo in the email. I my property file, it is
"throttle.file.operations=2000". Thanks.
zhao
Michael Wilde wrote:
> >> If its set right, any chance that Swift or Karajan is limiting it
> >> somewhere?
> > 2000 for sure,
> > throttle.submit=off
> > throttle.host.submit=off
> > throttle.score.job.factor=off
> > throttle.transfers=2000
> > throttle.file.operation=2000
> Looks like a typo in your properties, Zhao - if the text above came
> from your swift.properties directly:
> vs operations with an s as per the properties doc:
> throttle.file.operations=8
> #throttle.file.operations=off
> Which doesnt explain why we're seeing 100 when the default is 8 ???
> - Mike
> On 4/13/08 3:39 PM, Zhao Zhang wrote:
>> Hi, Mike
>>> Ben, your analysis sounds very good. Some notes below, including
>>> questions for Zhao.
>>> On 4/13/08 2:57 PM, Ben Clifford wrote:
>>>>> Ben, can you point me to the graphs for this run? (Zhao's
>>>>> *99cy0z4g.log)
>>>> http://www.ci.uchicago.edu/~benc/report-dock2-20080412-1609-99cy0z4g
>>>>> Once stage-ins start to complete, are the corresponding jobs
>>>>> initiated quickly, or is Swift doing mostly stage-ins for some
>>>>> period?
>>>> In the run dock2-20080412-1609-99cy0z4g, jobs are submitted (to
>>>> falkon) pretty much right as the corresponding stagein completes. I
>>>> have no deeper information about when the worker actually starts to
>>>> run.
>>>>> Zhao indicated he saw data indicating there was about a 700 second
>>>>> lag from
>>>>> workflow start time till the first Falkon jobs started, if I
>>>>> understood
>>>>> correctly. Do the graphs confirm this or say something different?
>>>> There is a period of about 500s or so until stuff starts to happen;
>>>> I haven't looked at it. That is before stage-ins start too, though,
>>>> which means that i think this...
>>>>> If the 700-second delay figure is true, and stage-in was
>>>>> eliminated by copying
>>>>> input files right to the /tmp workdir rather than first to
>>>>> /shared, then we'd
>>>>> have:
>>>>> 1190260 / ( 1290 * 2048 ) = .45 efficiency
>>>> calculation is not meaningful.
>>>> I have not looked at what is going on during that 500s startup
>>>> time, but I plan to.
>>> Zhao, what SVN rev is your Swift at?  Ben fixed an N^2 mapper
>>> logging problem a few weeks ago. Could that cause such a delay, Ben?
>>> It would be very obvious in the swift log.
>> The version is Swift svn swift-r1780 cog-r1956
>>>>> I assume we're paying the same staging price on the output side?
>>>> not really - the output stageouts go very fast, and also because
>>>> job ending is staggered, they don't happen all at once.
>>>> This is the same with most of the large runs I've seen (of any
>>>> application) - stageout tends not to be a problem (or at least, no
>>>> where near the problems of stagein).
>>>> All stageins happen over a period t=400 to t=1100 fairly smoothly.
>>>> There's rate limiting still on file operations (100 max) and file
>>>> transfers (2000 max) which is being hit still.
>>> I thought Zhao set file operations throttle to 2000 as well.  Sounds
>>> like we can test with the latter higher, and find out what's
>>> limiting the former.
>>> Zhao, what are your settings for property throttle.file.operations?
>>> I assume you have throttle.transfers set to 2000.
>>> somewhere?
>> 2000 for sure,
>> throttle.submit=off
>>>> I think there's two directions to proceed in here that make sense
>>>> for actual use on single clusters running falkon (rather than
>>>> trying to cut out stuff randomly to push up numbers):
>>>>  i) use some of the data placement features in falkon, rather than
>>>> Swift's
>>>>     relatively simple data management that was designed more for
>>>> running
>>>>     on the grid.
>>> Long term: we should consider how the Coaster implementation could
>>> eventually do a similar data placement approach. In the meantime
>>> (mid term) examining what interface changes are needed for Falkon
>>> data placement might help prepare for that. Need to discuss if that
>>> would be a good step or not.
>>>>  ii) do stage-ins using symlinks rather than file copying. this makes
>>>>      sense when everything is living in a single filesystem, which
>>>> again
>>>>      is not what Swift's data management was originally optimised for.
>>> I assume you mean symlinks from shared/ back to the user's input files?
>>> That sounds worth testing: find out if symlink creation is fast on
>>> NFS and GPFS.
>>> Is another approach to copy direct from the user's files to the /tmp
>>> workdir (ie wrapper.sh pulls the data in)? Measurement will tell if
>>> symlinks alone get adequate performance. Symlinks do seem an easier
>>> first step.
>>>> I think option ii) is substantially easier to implement (on the
>>>> order of days) and is generally useful in the single-cluster,
>>>> local-source-data situation that appears to be what people want to
>>>> do for running on the BG/P and scicortex (that is, pretty much
>>>> ignoring anything grid-like at all).
>>> Grid-like might mean pulling data to the /tmp workdir directly by
>>> the wrapper - but that seems like a harder step, and would need
>>> measurement and prototyping of such code before attempting. Data
>>> transfer clients that the wrapper script can count on might be an
>>> obstacle.
>>>> Option i) is much harder (on the order of months), needing a very
>>>> different interface between Swift and Falkon than exists at the
>>>> moment.
