[Swift-devel] Re: Another performance comparison of DOCK
Michael Wilde wilde at mcs.anl.gov
Sun Apr 13 16:52:56 CDT 2008
 >> If its set right, any chance that Swift or Karajan is limiting it
 >> somewhere?
 > 2000 for sure,
 > throttle.submit=off
 > throttle.host.submit=off
 > throttle.score.job.factor=off
 > throttle.transfers=2000
 > throttle.file.operation=2000
Looks like a typo in your properties, Zhao - if the text above came from
your swift.properties directly:
vs operations with an s as per the properties doc:
throttle.file.operations=8
#throttle.file.operations=off
Which doesnt explain why we're seeing 100 when the default is 8 ???
- Mike
On 4/13/08 3:39 PM, Zhao Zhang wrote:
> Hi, Mike
> Michael Wilde wrote:
>> Ben, your analysis sounds very good. Some notes below, including
>> questions for Zhao.
>> On 4/13/08 2:57 PM, Ben Clifford wrote:
>>>> Ben, can you point me to the graphs for this run? (Zhao's
>>>> *99cy0z4g.log)
>>> http://www.ci.uchicago.edu/~benc/report-dock2-20080412-1609-99cy0z4g
>>>> Once stage-ins start to complete, are the corresponding jobs
>>>> initiated quickly, or is Swift doing mostly stage-ins for some period?
>>> In the run dock2-20080412-1609-99cy0z4g, jobs are submitted (to
>>> falkon) pretty much right as the corresponding stagein completes. I
>>> have no deeper information about when the worker actually starts to run.
>>>> Zhao indicated he saw data indicating there was about a 700 second
>>>> lag from
>>>> workflow start time till the first Falkon jobs started, if I understood
>>>> correctly. Do the graphs confirm this or say something different?
>>> There is a period of about 500s or so until stuff starts to happen; I
>>> haven't looked at it. That is before stage-ins start too, though,
>>> which means that i think this...
>>>> If the 700-second delay figure is true, and stage-in was eliminated
>>>> by copying
>>>> input files right to the /tmp workdir rather than first to /shared,
>>>> then we'd
>>>> have:
>>>> 1190260 / ( 1290 * 2048 ) = .45 efficiency
>>> calculation is not meaningful.
>>> I have not looked at what is going on during that 500s startup time,
>>> but I plan to.
>> Zhao, what SVN rev is your Swift at?  Ben fixed an N^2 mapper logging
>> problem a few weeks ago. Could that cause such a delay, Ben? It would
>> be very obvious in the swift log.
> The version is Swift svn swift-r1780 cog-r1956
>>>> I assume we're paying the same staging price on the output side?
>>> not really - the output stageouts go very fast, and also because job
>>> ending is staggered, they don't happen all at once.
>>> This is the same with most of the large runs I've seen (of any
>>> application) - stageout tends not to be a problem (or at least, no
>>> where near the problems of stagein).
>>> All stageins happen over a period t=400 to t=1100 fairly smoothly.
>>> There's rate limiting still on file operations (100 max) and file
>>> transfers (2000 max) which is being hit still.
>> I thought Zhao set file operations throttle to 2000 as well.  Sounds
>> like we can test with the latter higher, and find out what's limiting
>> the former.
>> Zhao, what are your settings for property throttle.file.operations?
>> I assume you have throttle.transfers set to 2000.
>> somewhere?
> 2000 for sure,
> throttle.submit=off
>>> I think there's two directions to proceed in here that make sense for
>>> actual use on single clusters running falkon (rather than trying to
>>> cut out stuff randomly to push up numbers):
>>>  i) use some of the data placement features in falkon, rather than
>>> Swift's
>>>     relatively simple data management that was designed more for running
>>>     on the grid.
>> Long term: we should consider how the Coaster implementation could
>> eventually do a similar data placement approach. In the meantime (mid
>> term) examining what interface changes are needed for Falkon data
>> placement might help prepare for that. Need to discuss if that would
>> be a good step or not.
>>>  ii) do stage-ins using symlinks rather than file copying. this makes
>>>      sense when everything is living in a single filesystem, which again
>>>      is not what Swift's data management was originally optimised for.
>> I assume you mean symlinks from shared/ back to the user's input files?
>> That sounds worth testing: find out if symlink creation is fast on NFS
>> and GPFS.
>> Is another approach to copy direct from the user's files to the /tmp
>> workdir (ie wrapper.sh pulls the data in)? Measurement will tell if
>> symlinks alone get adequate performance. Symlinks do seem an easier
>> first step.
>>> I think option ii) is substantially easier to implement (on the order
>>> of days) and is generally useful in the single-cluster,
>>> local-source-data situation that appears to be what people want to do
>>> for running on the BG/P and scicortex (that is, pretty much ignoring
>>> anything grid-like at all).
>> Grid-like might mean pulling data to the /tmp workdir directly by the
>> wrapper - but that seems like a harder step, and would need
>> measurement and prototyping of such code before attempting. Data
>> transfer clients that the wrapper script can count on might be an
>> obstacle.
>>> Option i) is much harder (on the order of months), needing a very
>>> different interface between Swift and Falkon than exists at the moment.
