[Swift-devel] Re: Another performance comparison of DOCK
Mihael Hategan
hategan at mcs.anl.gov
Sun Apr 13 17:09:03 CDT 2008
Then my guess is that the system itself (swift + server + FS) cannot
sustain a much higher rate than 100 things per second. In principle
setting those throttles to 2000 pretty much means that you're trying to
start 2000 gridftp connections and hence 2000 gridftp processes on the
server.
On Sun, 2008-04-13 at 17:58 -0500, Zhao Zhang wrote:
> Hi, Mike
> It is just a typo in the email. I my property file, it is
> "throttle.file.operations=2000". Thanks.
> zhao
> Michael Wilde wrote:
> > >> If its set right, any chance that Swift or Karajan is limiting it
> > >> somewhere?
> > > 2000 for sure,
> > > throttle.submit=off
> > > throttle.host.submit=off
> > > throttle.score.job.factor=off
> > > throttle.transfers=2000
> > > throttle.file.operation=2000
> > Looks like a typo in your properties, Zhao - if the text above came
> > from your swift.properties directly:
> > vs operations with an s as per the properties doc:
> > throttle.file.operations=8
> > #throttle.file.operations=off
> > Which doesnt explain why we're seeing 100 when the default is 8 ???
> > - Mike
> > On 4/13/08 3:39 PM, Zhao Zhang wrote:
> >> Hi, Mike
> >>> Ben, your analysis sounds very good. Some notes below, including
> >>> questions for Zhao.
> >>> On 4/13/08 2:57 PM, Ben Clifford wrote:
> >>>>> Ben, can you point me to the graphs for this run? (Zhao's
> >>>>> *99cy0z4g.log)
> >>>> http://www.ci.uchicago.edu/~benc/report-dock2-20080412-1609-99cy0z4g
> >>>>> Once stage-ins start to complete, are the corresponding jobs
> >>>>> initiated quickly, or is Swift doing mostly stage-ins for some
> >>>>> period?
> >>>> In the run dock2-20080412-1609-99cy0z4g, jobs are submitted (to
> >>>> falkon) pretty much right as the corresponding stagein completes. I
> >>>> have no deeper information about when the worker actually starts to
> >>>> run.
> >>>>> Zhao indicated he saw data indicating there was about a 700 second
> >>>>> lag from
> >>>>> workflow start time till the first Falkon jobs started, if I
> >>>>> understood
> >>>>> correctly. Do the graphs confirm this or say something different?
> >>>> There is a period of about 500s or so until stuff starts to happen;
> >>>> I haven't looked at it. That is before stage-ins start too, though,
> >>>> which means that i think this...
> >>>>> If the 700-second delay figure is true, and stage-in was
> >>>>> eliminated by copying
> >>>>> input files right to the /tmp workdir rather than first to
> >>>>> /shared, then we'd
> >>>>> have:
> >>>>> 1190260 / ( 1290 * 2048 ) = .45 efficiency
> >>>> calculation is not meaningful.
> >>>> I have not looked at what is going on during that 500s startup
> >>>> time, but I plan to.
> >>> Zhao, what SVN rev is your Swift at? Ben fixed an N^2 mapper
> >>> logging problem a few weeks ago. Could that cause such a delay, Ben?
> >>> It would be very obvious in the swift log.
> >> The version is Swift svn swift-r1780 cog-r1956
> >>>>> I assume we're paying the same staging price on the output side?
> >>>> not really - the output stageouts go very fast, and also because
> >>>> job ending is staggered, they don't happen all at once.
> >>>> This is the same with most of the large runs I've seen (of any
> >>>> application) - stageout tends not to be a problem (or at least, no
> >>>> where near the problems of stagein).
> >>>> All stageins happen over a period t=400 to t=1100 fairly smoothly.
> >>>> There's rate limiting still on file operations (100 max) and file
> >>>> transfers (2000 max) which is being hit still.
> >>> I thought Zhao set file operations throttle to 2000 as well. Sounds
> >>> like we can test with the latter higher, and find out what's
> >>> limiting the former.
> >>> Zhao, what are your settings for property throttle.file.operations?
> >>> I assume you have throttle.transfers set to 2000.
> >>> somewhere?
> >> 2000 for sure,
> >> throttle.submit=off
> >>>> I think there's two directions to proceed in here that make sense
> >>>> for actual use on single clusters running falkon (rather than
> >>>> trying to cut out stuff randomly to push up numbers):
> >>>> i) use some of the data placement features in falkon, rather than
> >>>> Swift's
> >>>> relatively simple data management that was designed more for
> >>>> running
> >>>> on the grid.
> >>> Long term: we should consider how the Coaster implementation could
> >>> eventually do a similar data placement approach. In the meantime
> >>> (mid term) examining what interface changes are needed for Falkon
> >>> data placement might help prepare for that. Need to discuss if that
> >>> would be a good step or not.
> >>>> ii) do stage-ins using symlinks rather than file copying. this makes
> >>>> sense when everything is living in a single filesystem, which
> >>>> again
> >>>> is not what Swift's data management was originally optimised for.
> >>> I assume you mean symlinks from shared/ back to the user's input files?
> >>> That sounds worth testing: find out if symlink creation is fast on
> >>> NFS and GPFS.
> >>> Is another approach to copy direct from the user's files to the /tmp
> >>> workdir (ie wrapper.sh pulls the data in)? Measurement will tell if
> >>> symlinks alone get adequate performance. Symlinks do seem an easier
> >>> first step.
> >>>> I think option ii) is substantially easier to implement (on the
> >>>> order of days) and is generally useful in the single-cluster,
> >>>> local-source-data situation that appears to be what people want to
> >>>> do for running on the BG/P and scicortex (that is, pretty much
> >>>> ignoring anything grid-like at all).
> >>> Grid-like might mean pulling data to the /tmp workdir directly by
> >>> the wrapper - but that seems like a harder step, and would need
> >>> measurement and prototyping of such code before attempting. Data
> >>> transfer clients that the wrapper script can count on might be an
> >>> obstacle.
> >>>> Option i) is much harder (on the order of months), needing a very
> >>>> different interface between Swift and Falkon than exists at the
> >>>> moment.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
