[Swift-devel] Re: plan for 0.5 release
Mihael Hategan
hategan at mcs.anl.gov
Thu Apr 3 04:22:51 CDT 2008
On Thu, 2008-04-03 at 06:27 +0000, Ben Clifford wrote:
> > Can you explain a bit more about the "data channel doesn't work for a bunch of
> > sites" problem?
> There's some channel reuse code that went into cog in the past few months.
> It gets enabled when it detects that it has been pointed at a specific
> version of the GridFTP server (which is in itself a bug as it should
> really work for lots of versions).
Not quite. I've put that in precisely because some versions didn't work.
> The code appears to not work. So when
> Swift is pointed at a gridftp server of that version, it cannot stage in
> or out files. When it is pointed at a different version gridftp server,
> the two bugs cancel each other out - data channel reuse is not used, and
> so Swift can stage files in and out.
