[Swift-devel] Re: plan for 0.5 release
    Michael Wilde
    wilde at mcs.anl.gov
    Thu Apr  3 07:14:13 CDT 2008
Mihael, Ben,
How well do you understand the problem and whats your confidence in
being able to reliably fix it?
It seems best to disable it (or adjust things) to get more reliable
operation across all or more sites, at the expense of performance on
some sites, while its being fixed.
Mihael, is this bug on your plate? Whats your estimate of effort involved?
- Mike
On 4/3/08 4:22 AM, Mihael Hategan wrote:
> On Thu, 2008-04-03 at 06:27 +0000, Ben Clifford wrote:
>>> Can you explain a bit more about the "data channel doesn't work for a bunch of
>>> sites" problem?
>> There's some channel reuse code that went into cog in the past few months.
>> It gets enabled when it detects that it has been pointed at a specific
>> version of the GridFTP server (which is in itself a bug as it should
>> really work for lots of versions).
> Not quite. I've put that in precisely because some versions didn't work.
>>  The code appears to not work. So when
>> Swift is pointed at a gridftp server of that version, it cannot stage in
>> or out files. When it is pointed at a different version gridftp server,
>> the two bugs cancel each other out - data channel reuse is not used, and
>> so Swift can stage files in and out.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
